Captive brake caliper and wheel spacers
Old May 10, 2007 | 12:21 PM
Rales's Avatar
All Vacuum
For the spacers Im probalby going to have drawings made up and sent to a prototype shop i know in michigan that will hook me up.
As for the brake caliper mount its the same on mine, but if you hit it just right it falls out. Im thinking about making a cutter to cut a very small slot into the welded mount on the swing arm and then modify the bracket with added peice and then they slide in and out but wont fall out.
AIM: SolderedLego
Toys are fun, atleast they dont say NO.
Like to drink buy a drinking tee
http://www.tampaforums.com/forums/mi...s-more-289609/
Old May 10, 2007 | 12:31 PM
Slo Poke's Avatar
chicken sirloin
they already make all the parts you need....endurance racers use it to do quick changes....educate urself man.....
Old May 10, 2007 | 12:38 PM
TNathe's Avatar
educating urself < discovering something out on your own
although the latter of the two is usually more cost and time prohibitive but the reward of statisfaction is much greater!
-do you have any links or something you could share with oh educated one
Old May 10, 2007 | 12:39 PM
Slo Poke's Avatar
chicken sirloin
pvm is a leader in quick change stuff....yeah it might not be homemade, but its pretty good ...and rales put an ohlins suspension on his RC51, why wouldnt he spend the $$ for some pvm stuff????
Old May 10, 2007 | 12:48 PM
TNathe's Avatar
thanks.
Old May 10, 2007 | 01:47 PM
Rales's Avatar
All Vacuum
Slo, I had been searching the rc forums and and the rouge board with no luck on captive stuff produced for the RC, I know its made for other endurance bikes but I hadnt any luck yet with the RC. I will check them out and hopefully they have what I need. Trust me money is a concern but they cant be that expensive lol.
AIM: SolderedLego
Old May 10, 2007 | 02:50 PM
  #17 (permalink)
Rales's Avatar
All Vacuum
Checked out PVM and they seem to have some nice setups. Although very tecnical and over kill for my concern. For an endurance racer it would be great but I dont need to change a wheel in 7 seconds lol. I bet there systems are also hundreds of dollars. All I want is for the spacers to not spill across the floor when im trying to put a wheel on or off.
AIM: SolderedLego
Old May 11, 2007 | 05:40 AM
  #18 (permalink)
TNathe's Avatar
put a small dab of super glue or somthing on it then mount the wheel and after its mounted take a pair of pliers and turn the spacer so it breaks loose from the glue. <--- That's the Dade City Shade Tree mechanic's way of doing it
Old May 11, 2007 | 08:46 AM
  #19 (permalink)
Rales's Avatar
All Vacuum
Hmm, why not just weld the spacer right to the rim...no problems mounting then....
AIM: SolderedLego
