Regulator/Rectifier
Regulator/Rectifier
When you're riding your motorcycle and the headlight/gauges suddenly dim and the bike starts sputtering like it's running out of gas, then the headlight/gauges get super bright, then dim again, is that the regulator/rectifier going bad?
I tore into the bike trying to find a problem...everything looked fine except for a loose negative power cable at the battery post. Could a loose cable simulate a bad regulator like that?
