Pilot Powers...
Michelin Pilot Power 2CT
Still not convinced that Pilot Power is for you? Well, now there’s a dual-compound version, a direct descendant of our MotoGP technology. With a softer rubber mix on the shoulders, the new Pilot Power 2CT will satisfy even the most demanding sport riders. Want to carve corners at extreme lean angles? Do you feel like you’ve found the limit with your current tires? Does your new literbike have more power than your tires can use? If so, then it’s time to switch to the new Pilot Power 2CT.
HMMM guess when it comes time for new tires, the 2ct is the way to go...
Warning:anticipation of next sig may cause heart failure.......
www.myspace.com/gloveman1386
