changin my sprocket for wheelies
Old Aug 22, 2006 | 08:39 AM
dystopiam's Avatar
destruktive20@gmail.com
Default changin my sprocket for wheelies
Could I change it out myself? How much would it cost at a local shop like barneys? Thanks.
Its too hard to slip it in 1st to get up so I wanted a tooth setup for power wheelies.
Old Aug 22, 2006 | 08:45 AM
Carlos's Avatar
**International Baller**
Bro....if your bike wont even come up in 1st....dont even wheelie it!
Old Aug 22, 2006 | 08:47 AM
dystopiam's Avatar
It will but I gotta get to 9k rpms and slip, if I changed the sprocket wont the power just lift it up easy?
Old Aug 22, 2006 | 08:49 AM
Cecil's Avatar
gone fishin
Sprocket changes are pretty easy.
Just need some basic tools.
If you mod the rear, you may end up needing a longer chain.
You may be able to drop the front a tooth, ang go up 1 or 2 in the rear and use your existing chain.
Ideally you would replace both the chain and sprockets... but what ever.
Be careful with the countershaft nut and do not foret the o-rings on the master-link.
Do it yourself.... learn how..... have fun...
Old Aug 22, 2006 | 09:24 AM
Cammo's Avatar
Is on his way
If you need a new sprocket to wheelie a bike then you shouldnt be doing wheelies. Didnt you just get this bike?
Go -1 in the front and +2 in the rear. You can pretty much do standups in 4th gear with that set-up. Changing them is fairly simple.
Old Aug 22, 2006 | 09:40 AM
LS1ETR's Avatar
learn stock first. Like they have said. If you cant do it stock .... well you need to learn. Gearing it is only going to make it more twitchy for you.
what do you ride?
Old Aug 22, 2006 | 10:01 AM
TNathe's Avatar
Old Aug 22, 2006 | 10:18 AM
MtuRbo2's Avatar
sergee-hoe
9k sounds about right. try rolling on the throttle after it comes up...
Old Aug 22, 2006 | 10:32 AM
Matt the Pilot's Avatar
ZAP yo dumb ass!!!!
What do you ride? Please tell me a 250 or something. Because I could get my 600 up in 3rd. On stock gearing.
Matt Patton
RIP Jason Harrill 6-12-06: Died doing what he loved
Old Aug 22, 2006 | 10:51 AM
Cammo's Avatar
Is on his way
But arent you a professional stuntaaa?
