Ninja 650R
Old Feb 21, 2006 | 06:12 PM
Shaun_GST's Avatar
<<<Tampa<<< >>>Bay>>>
Default Ninja 650R
Anyone have any experience with these yet. Opinions?
http://www.motorsportstampa.com/new_...sc=Motorcycles
Edit: On second thought, I think I remember sitting on one and it felt like I was sitting on a toy.
Gripped XS | 18-55 IS | 50mm f/1.8 MK II | Sunpak 5000af
Old Feb 21, 2006 | 06:22 PM
Cecil's Avatar
gone fishin
I watched a piece on the Speed Channel where they reviewed the bike.
It is suppose to be direct competetion for the SV650.
The riders said it was plenty powerful and overall a very fun bike to ride.
Old Feb 21, 2006 | 06:24 PM
Cecil's Avatar
gone fishin
Here's a little more food for thought...
MSRP $6,299.00 now available from your local Kawasaki dealer
Unique look and feel grew from specific design team objectives seeking to blend attractiveness with power.
Look at Kawasaki's all new NINJA® 650R sportbike and the first impression is one of pure design appreciation. Look a little longer and many of the innovative engine and chassis elements begin to come into play. But the entire package doesn't truly project its intended engineering outcome until the motorcycle is viewed with a rider seemingly melded into its unique posture. Because the 650R was meant to have broad rider appeal, Kawasaki's development team began its task with the rider-not the motorcycle.
Focusing on all kinds of riders, and all kinds of riding, Kawasaki carefully studied the interface between human and machine. Riding positions were studied to discover which instilled the most confidence. Narrowing the distance between foot pegs and striving for a lower seat height and low effort controls all played into the design efforts.
Ultimately, this exceptionally well-proportioned NINJA 650R represents a genre of motorcycling new to Kawasaki-one that finds itself at home with both novices and experienced riders, and one that will be seen equally in daily midtown commuting situations as well as week-end highway getaways.
A combination of versatility, performance and style, this motorcycle knows no boundaries in terms of rider appeal. It will be a first-time purchase for some, a second or third motorcycle for others, and for all, it will be fun. Powered by a compact two cylinder engine mounted in a sleek, lightweight chassis, this extremely maneuverable model will earn its rank as one of the most rider friendly units in today's marketplace.
The very compact liquid-cooled, DOHC, 8-valve 649cc Parallel Twin with fuel injection delivers a smooth responsiveness that is tuned for rider-friendly power characteristics-especially in the low and medium rpm ranges that will inspire confidence in new motorcyclists. Its excellent mid-range characteristics will make the 650R a natural for medium speed commuting environments. And slipping in and out of traffic will be a cinch for this new entry, as its lightweight trellis frame and laydown shock also contribute to its overall compactness.
While the powerplant on this new NINJA is compact, it is anything but minimal in its output. Just gauge the 650R's roll-on response when making a highway pass and any concerns in that area quickly subside. The engineers called on their vast experience building NINJA supersport machines to develop a motorcycle possessing performance characteristics that will be a match for anything currently available in the middleweight arena, including those with larger displacement.
Some of the engine's characteristics:
- Triangular layout of the crankshaft and transmission shafts make the engine very short, front-to-back
- The transmission's input shaft, output shaft, and change drum are contained in a cassette-style package that both works for the 650R's compact layout, and facilitates transmission maintenance
- Engine height is reduced through the use of a semi-dry sump design
- This new Kawasaki has a plated, liner-less aluminum cylinder which is lightweight; its narrow cylinder pitch reduces
engine width
- Under-engine muffler improves mass centralization and lowers the 650R center of gravity
Some of the chassis design elements:
- Compact engine design allows use of a slim, minimalist frame, which results in a design that is narrow at the knees and feet
- Light and nimble handling characteristics are one of the benefits of the extremely short wheelbase of this motorcycle
- A long swingarm is used, so both rear suspension and handling are improved
- Engineers used 3-D analysis to achieve the ideal stiffness balance for the frame, which contributes greatly to its handling characteristics
- Frame construction is of high-tensile steel, rivaling the lightness of aluminum frames
- The layout of the offset single-shock rear suspension allows the battery to be located next to the shock rather than beneath it-making for a slim design and lower seat height
Bringing the motorcycle to a stop is handled by triple petal disc brakes that look as good as they perform. And the attractive six-spoke supersport-style wheels give the 650R a "light" look while reducing unsprung weight.
This new entry sports a very aggressive headlight design, an aerodynamic windscreen and full fairing, and front turn signals integrated into the faring. The flowing bodywork includes a slim tail cowl with flush-surface tail lamp lens giving the new NINJA 650R a slim, agile appearance from the rear.
Also contributing to the slim design appearance is a two-tone seat and a sculpted fuel tank.
Instrumentation abounds with this multi-purpose motorcycle. A compact step-motor speedometer features an LCD display with digital readouts for odometer, twin tripmeter, and clock as well as an LED water temperature warning lamp.
Few will look at or ride Kawasaki's NINJA 650R and fail to come away impressed. Both from a design and a performance benchmark, the team responsible for this new motorcycle has accomplished their stated goal-creating a new category for Kawasaki where every rider, new, old, male, female, experienced or novice-can find a reason to park this one in the garage.
SPECIFICATIONS
Engine Type: 4-Stroke, Liquid-Cooled, DOHC, 4 Valve Cylinder Head, Parallel Twin
Displacement: 649 cc
Bore & Stroke: 83.0 x 60.0 mm
Horsepower: 71 hp (53kW)
Maximum Torque:
48.5 ft-lbf (66 Nm) @ 7000 RPM
Compression Ratio: 11.3:1
Carburetor: DFI with Keihin 38mm Throttle Bodies (2)
Transmission: 6-Speed
Final Drive: O-Ring Chain
Rake/Trail: 25°/4.2 in.
Front Wheel Travel: 120mm
Rear Wheel Travel: 130mm
Front Tire Size: 120/70-17
Rear Tire Size: 160/60-17
Wheelbase: 1.4m
Front Suspension: 41mm Hydraulic Telescopic Fork
Rear Suspension: Offset Laydown Single Shock
Front Brake Type: Dual 300mm Petal Disc with 2-Piston Caliper
Rear Brake Type: Single 220mm Petal Disc
Fuel Tank Capacity: 4.1 gal.
Seat Height: 78.5cm (30.9 in)
Dry Weight: 174kg (383 lbs)
Color: Galaxy Silver/Metallic Graystone, Ebony/Galaxy Silver
Warranty: 12 months
(Click image thumbnail for larger resolution)
Old Feb 21, 2006 | 07:17 PM
Dragin's Avatar
Got Mud?
Its not a bad looking bike, a friend of mine was looking at one. And that one hell of a rear set.
Old Feb 21, 2006 | 07:30 PM
GSRBoy's Avatar
Living the dream
that thing looks badass! I'm *hopefully* going to be in the market for a bike at the end of summer and if they had these used I would def. pick one up!
Old Feb 22, 2006 | 03:50 AM
Shaun_GST's Avatar
Yeah they seem to be extremely well priced. But the problem I have with them ,like I said, they are smaller than the average bike. i'm 6'2 and it felt way too small for me.
Old Feb 22, 2006 | 05:28 AM
Cecil's Avatar
gone fishin
Even the liter bikes feel small these days...
Old Feb 22, 2006 | 05:46 AM
nasdstang's Avatar
need turbo stuff,pm me
i sat on one when we went to get the wifes bike, she originally wanted that one. i didnt like it, sit up too straight
they also have a 750
-Ronald Reagan
Old Feb 22, 2006 | 06:00 AM
DSTGST's Avatar
factory turbo charged car
my buddy has the silver one. he really likes it. expecially for the price. it handles really well but he is still breaking it in.
TURBO IS THE ONLY WAY TO GO. IF YOU DON'T HAVE ONE GET ONE. HA HA
ALSO FRIENDS DON'T LET FRIENDS DRIVE STOCK.
