Clutch Plates
Old Dec 29, 2005 | 06:46 AM
UrbanRR's Avatar
Clutch it up!
Default Clutch Plates
For a 03 600rr is there a gasket or a sealer. I called motorsports and said there was a sealer for some reason i thought there was a gasket.? So with the sealer this make it any harder to do?
USMC
In Iraq be back March 21 2008
AIM is Urbangixxer714
Old Dec 29, 2005 | 07:06 AM
TNathe's Avatar
your already putting a clutch in an 03? You mean a liquid sealer between the clutch cover and engine case? If thats what you mean it doesnt make it any harder just lay a nice bead of sealant and bolt it together and check for leaks of course.
Old Dec 29, 2005 | 07:12 AM
UrbanRR's Avatar
Clutch it up!
yea. I bought the bike used. Blah. Thanks man just what i wanted to know.
USMC
Old Dec 29, 2005 | 07:15 AM
LuckyH's Avatar
How many miles are on it? I just bought a used 04 600 RR and it seems fine at 6k miles. Even has the original tires on it.
Old Dec 29, 2005 | 07:28 AM
UrbanRR's Avatar
Clutch it up!
i got 8000 now, I already got a new rear tire.
USMC
Old Dec 29, 2005 | 07:32 AM
UrbanRR's Avatar
Clutch it up!
called the local dealer to get a price on how much it would be for them do the plates $150 dollars. i just gotta wait till i get the chance to do it with a friend of mine.
USMC
Old Dec 29, 2005 | 07:44 AM
Slimnplatinum's Avatar
Wow new clutch plates on a 2003?
Old Dec 29, 2005 | 08:14 AM
UrbanRR's Avatar
Clutch it up!
just plates..
USMC
Old Dec 29, 2005 | 09:09 AM
TNathe's Avatar
somebodys been trying 2nd or 3rd gear wheelies or drag racing eh?
BTW: Scrape all the old sealant off the mating surfaces to give you a nice flat area to apply new sealant. And no need to gob that stuff on there cause when you assemble the two halves together you will get a lot of extra sealant mushing out.
Old Dec 29, 2005 | 10:07 AM
F*r*a*n*k*e*i's Avatar
Do you need that special Honda clutch basket tool on the '03s? Better check. I know on the old Hondas you had to have a special Honda part to get the clutch assembly apart, and the thing is like $30-$40. Fuckers.
