motor swap?
Old Aug 26, 2005 | 07:02 PM
Corner Worker's Avatar
got a motor, no throttle bodies, no starter....$600. the reason you put a 929 motor in a 600 is for the sleeper effect. anyone who knows hondas can tell a 929's body work from a f4i, but they cant tell the motors apart.....very sneaky
the cause of all that is evil
Old Aug 26, 2005 | 07:04 PM
954RR's Avatar
Originally Posted by Cronic
I think it would be nice to have a 370lbs bike with a 929 engine. It's just an idea Im toying with. Nothing concrete just yet. I don't even know how much the engine and tranny would cost. I would assume not too much.
The 929 already weighs close to 370lbs. The weight savings (if any) would be negligible. Spend the money and just get a 929, plus the better forks, brakes, etc. It would be cheaper than trying to stuff the motor in a F4 frame......which you have to cut up to even get it in there. It would handle like shit too.
EDIT - If you want a "sleeper", just get some used F4 plastics and make them fit the 929.
2002 954RR
-135rwhp
0-110mph in 6.7 seconds
Old Aug 26, 2005 | 07:10 PM
954RR's Avatar
BTW - Look at the 929 frame sometime. The swingarm attaches to the motor which is used as a stressed member and bolted to the frame. The F4 uses the conventional way of having the swingarm bolted to the frame and the motor is just hung in there. You'd have to chop the hell out of the F4 frame to get it in there at all since it is probably quite a bit wider (plus the whole swingarm attachment deal). Then you'd have to worry about the rear shock attachment since that would be totally different.
You could try to get a 900RR motor in there. Many people have done the swap with F3's which is very similar to the F4.
2002 954RR
-135rwhp
