What do you think about Victory Motorcycle's?
http://victorymotorcycles.polarisind...aspx?Year=2005
Engine
Engine Type 4-stroke 50° V-Twin
Cooling System Air/Oil
Displacement 92 cu in/1507cc
Bore x Stroke 97x102mm
Compression Ratio 9.2:1
Valve Train Single overhead camshafts with 4 valves per cylinder, self-adjusting cam chains, hydraulic lifters
Fuel System Electronic Fuel Injection with 44mm throttle bodies
Fuel Capacity 4.5/17.0 U.S. gallons/liters
Exhaust Staggered slash-cut dual exhaust with common volume
Oil Capacity 6.0qts/5.7ltr
Charging System 38 amps max output
Battery 12 volts/18 amp hours
Primary Drive Gear drive with torque compensator
Clutch Wet, multi-plate
Transmission 5-speed constant mesh
Final Drive Reinforced belt
Brakes
Front Brake 300mm floating rotor with 4-piston caliper
Rear Brake 300mm floating rotor with 2-piston caliper
Dimensions
Length 96.3/2445 in/mm
Wheelbase 65.6/1690 in/mm
Seat Height 26.5/673 in/mm
Ground Clearance 5.8/148 in/mm
Rake/Trail 33.1°/5.28/134 in/mm
Dry Weight 620/281 lbs/kg
GVWR 1135/515 lbs/kg
Suspension
Front Suspension Conventional telescopic fork, 43mm diameter, 5.1in/130mm travel
Rear Suspension Single, mono-tube gas, forged and cast aluminum with rising rate linkage swing-arm, 3.9in/100mm travel, preload adjustable spring
Tires
Front Wheel 21x2.15in
Rear Wheel 18x5.0in
Front Tire 80 90/21 Dunlop Cruisemax
Rear Tire 180 55-B18 Dunlop D417
Colors
Solid Colors Black, Solar Red, Sonic Blue, Flame Yellow
Two-Toned Colors Pearl White over Vogue Silver, Polaris Anniversary Two-Tone
Multiple Colors Indy Red with Tribal Fade Flames, Black with Tribal Fade Flames
Engine
Brakes
Dimensions
Suspension
Tires
Rear Wheel 18x5.0in
Colors
I think they are very nice... unique lookin peices.
Where are they manufactured?
I personally wouldn't ride it...why....because to me a chick on any bike other then a sports bike, looks funny.....then again it may just be me , I am so little that I would look funny on anything BUT a sports bike lol...man sometimes it just doesn't pay to be 5'3 and 110 pounds soakin wet
~ Barbie
~ Barbie
~ Barbie
~ Barbie
