Bobster's ZX10R Heart Transplant
Old Apr 21, 2005 | 05:51 PM
  #31 (permalink)
bobster's Avatar
Originally Posted by B16aTeggy
what about the pistons?
sorry i didnt call u. i didnt get off work untill 6pm then i had to fix the 2fiddy.. glad to see u found sumone to help u
I had it ready to drop except a few mount bolts. After we figured that out, it wasnt too bad. I decided against the pistons cause between those and the gasket, the comp. would be too high for pump gas.
Old Apr 21, 2005 | 05:54 PM
  #32 (permalink)
bobster's Avatar
Originally Posted by LS1ETR
Damn bro... Thats sick.
Cant wait to see what that bad boy puts down!
yea, should be fun..
Old Apr 22, 2005 | 03:59 AM
  #33 (permalink)
TurboKaw's Avatar
What shop do you work on it at??
Old Apr 22, 2005 | 04:43 AM
  #34 (permalink)
bobster's Avatar
Exotic Cycles, Sarasota
Old Apr 22, 2005 | 05:10 AM
  #35 (permalink)
DogBoneZX10's Avatar
Dragging Plastics
Not to mention, Aftermarket forged pistons are heavier then the stock cast pistons. You'd slow your revs down.
I wouldnt have gone with bigger pistons either, but my cylendars were scored, so I had no choice, but to bore.
Even with high compression pistons and head gasket you can map to run 93 on the street. That's what I'm having to do. The bike runs better on Race fuel and a leaner map, but I do just fine on 93 octane and a rich map.
Do you really have to start a thread every time you go on a ride and see a guy with no helmet on?
Does it affect you that much that some random guy 1500 miles away went and paid his own money for a 1000?
Do we really have to fight over who uses the back brake or not?
Do you have to argue over stupid pointless shit on the Internet?
Old Apr 22, 2005 | 05:18 AM
  #36 (permalink)
bobster's Avatar
I had ordered JE 13.5 to 1 pistons. I already had the muzzy thin gasket. I cancelled the pistons cause he couldnt tell me for sure if i could run pump gas for approx. 14 to 1 comp. He said we could play with the valve lap to reduce if needed, but that defeats the purpose for the higher comp. to me. I will be at approx. 13.2 to 1 just with the gasket so im going with that. It also saves me from having to split the case etc..
Old Apr 22, 2005 | 05:45 AM
  #37 (permalink)
Dragging Plastics
That's right about where I'm at, 13.25:1. Out of all the stuff I did to my bike, The head work was the most noticable with the most gains. The head gasket isnt going to give you a whole bunch of HP. Maybe 5 if your lucky. You should consider getting the head ported while you have it off.
Old Apr 22, 2005 | 05:48 AM
  #38 (permalink)
Cecil's Avatar
gone fishin
...hehehe...
Old Apr 22, 2005 | 05:53 AM
  #39 (permalink)
bobster's Avatar
The heads for the 10 is sent from the factory for a hand porting. I am told that the head is as good as it gets already. I have seen the numbers for just the gasket. Its only 3.5 hp. But when you degree the cams and use a full exaust, the motor shines brightly. I will see...
Old Apr 22, 2005 | 06:14 AM
  #40 (permalink)
Dragging Plastics
Cool! Good luck with that. I'm curious to see how it does.
