Motorcycle exhaust questions
Old Apr 1, 2005 | 08:32 AM
SpyVO's Avatar
Default Motorcycle exhaust questions
OK, bear with me, this is a little wierd...
I've been wanting to fab up a different exhaust manifold for my car, which has a 2.3 turbo Ford. Finding materials is a PITA since I'm in Ft. Myers, but I noticed on my Boss's R1 that the primary pipes would probably work out really well to start with. Stock take-offs are pretty cheap, too.
What I need to know is this:
-What types of bikes use what type of material? I know GSX-Rs use titanium, which I can't work with now. Who uses stainless, or mild steel?
-What is the wall thickness of the pipes? Are they really thin to keep weight down? I'm sure it varies, but a ballpark figure would be great.
-Is there any place online that would have info about this kind of stuff? I've been searching about this stuff for a while, but none of it is really in-depth technical.
Thanks,
-Mike
'93 Coupe
"Notches kick ass!"
Old Apr 1, 2005 | 09:35 AM
TNathe's Avatar
Im not sure if the piping diameter from a motorcycle manifold is big enough for your app but I . Most are made of stainless I presume. Why not just go to www.JGSTOOLS.com And order what you need? They have mild steel with pretty thick walls so should be easy to work with. Thats another thing, I am gonna say that the wall thickness on a motorcycle manifold is too thin and wont support a 25lb turbo hanging off of it plus I dont think it will flow that well seeing as you have a 2300cc engine and there arent any I-4 motorcycle engines that big. Just some things to ponder cause Im not really sure.
Old Apr 1, 2005 | 10:28 AM
SpyVO's Avatar
OK, this is pretty much confirming what I thought. The thing to keep in mind about the tube sizing is that the bikes spin up to, what...11,000 RPM? I guess they need to use big pipes for that. I was pretty surprised when I saw the size of the exhaust on BIKES. The primaries are definately large enough for the stock 2.3 stuff (which might say something about the 2.3...)
THanks!
'93 Coupe
"Notches kick ass!"
Spyderxl98z24
Aug 31, 2004 10:51 PM
CO3BRA
Mar 17, 2004 06:33 AM
Dr Evo
May 14, 2001 07:17 PM
