problem with turn signals
I knocked off both of my front turn signals. So I get some new turn signals and rig them up and they dont work, but that is not the only problem, the back ones dont work now either. So.... anybody got any ideas on how to remedy this mylarge problem, or someone who knows how to fix it?
Thanks guys
Mike
Thanks guys
Mike
Escort in pieces.
240 For Sale 1500 obo
03 Kawasaki Ninja 250
Escort in pieces.
Well....
Your stock front turn signals should have had 3 seperate wires.
The first thing you need to do is figure out what wire is the GROUND, which wire is the NEGATIVE, and which wire is the POSITIVE.
You probably matched up the wrong wires from the new signals to the stock wiring. This probably caused a short...causing your back signals to blow out.
You should check your fuses.
"Ricey Hot Stuntaz" member #001
www.seductivecycles.com
its all about the wiring, give me a call mike 813-310-0330 and i'll have my friend rich (the guy w/ the zx6r) wire them up for ya, he's a wiring genius.
Semper Fi
Aim and Yahoo- Inkedupordie
Semper Fi
