Need some advice.
I've found that in autocrossing, I often want to downshift to 1st gear around some corners, namely 90 degree tight turns. I have always just stayed in 2nd gear and pushed on, despite not haing much power out of the corner.
The problem is this. It is very,very, very hard to get back into 1st gear coming from second. I believe it's because my 1st gear isn't syncronyzed, which makes it a struggle to push it back in 1st.
Should I stay in 2nd then? I read in GRM that one should stay in second, despite having the urge to downshift, stating that the time saved by having some extra power on tap will be negated by the time taken to downshift.
thanks.
thanks.
I can heel toe pretty consistantly, especially with the right shoes.
However, the problem is that in order for me to downshift to 1st, I would literally have to shove it in.
It's almost always better to stay in 2nd if you can carry any speed at all through the turn.
Unless you're driving an old MGB or something, your transmission is fully synchronized, even first gear. FWIW, I've driven cars belonging to people who, like you, said "it's impossible to downshift this car into first gear". Never driven one yet that was a problem, you just have to give the throttle a good blip to match the revs.
A good way to practice this is to teach yourself to do a clutchless downshift. Usually a 4-to-3 or 3-to-2 is easiest. Not quite the same as grabbing first, but if you get good at that, you will have mastered the concept required to make a smooth downshift to first. Good luck!
(and if you need more info on how to do a clutchless downshift, lemme know)
Originally posted by BeQuietAndDrive
I guess I'll practice doing the downshift...I doubt it's worth it though as my first gear is so short, it's good to maybe 15 mph.
The ONLY car I've ever driven where it was beneficial to downshift was my 2001 mustang cobra.
The 32valve motors are anemic below 4k rpms. That coupled with the fact that mustangs have to crawl through turns created a situation where downshifting didn't cost me any time. Essentially, I was going so slow, I had plenty of time to downshift in the turn before I would have been on the power if I hadn't downshifted.
You're probably going fast enough through the turn that the downshift is costing you time. I highly doubt that the power from teh additional revs will make up for the lost time from the downshift.
I see...I'll have to see how things pan out at the next Sunriders event. Thanks for all the advice.
It's times like these I wish for an engine with some low end torque..haha.
