Too much tire, too little power?
It's about that time again, my rear tires are all bald or chunking, and my fronts have started to show belts after last weekend. I was just wondering what the tire size consensus is, if any. For those who don't know my car, it is a 99.8% stock power 240, probably about 135hp to the ground. I'm looking at buying a set of Kumho MXs for my Z wheels and the cheapass inside of me (I own a 240 after all
) says to save $50 and get the 205/55/16, they'll be fine for my power level. Of course, i want to put the 225s on there.
...so the question i pose, would 225/50/16 make much more than a negligeable difference over 205/55/16 for my car (weighs 3000lb at the starting line, with upgraded shocks/springs) for a tire such as the Kumho MX? The followup would be at what point is the tire too wide? It seems like a lot of cars could run wider tires, but don't.
) says to save $50 and get the 205/55/16, they'll be fine for my power level. Of course, i want to put the 225s on there....so the question i pose, would 225/50/16 make much more than a negligeable difference over 205/55/16 for my car (weighs 3000lb at the starting line, with upgraded shocks/springs) for a tire such as the Kumho MX? The followup would be at what point is the tire too wide? It seems like a lot of cars could run wider tires, but don't.
yeah... i know for sure that Brian Davis and a few others have run 245s on S14. Maybe spacers would help give it enough clearance?
245s would work... not ideal, and honestly, i don't know if it'd be worth it for you. 225 MXs would be a very good combo though, IMO.
-93 MR2, #129 ES
-93 MR2, #129 ES
Ok, thanks for the input
245s would definitely rub without spacers, the 225 goodyear eagle f1s I have on now are like .5mm too wide......if they didn't have any raised text on the sidewalls I would be ok.
