SunRider's wrap up 11/15
![Default](https://www.tamparacing.com/forums/images/icons/icon1.gif)
I liked the course, you did well with what you had...even dropping down into 1st wasn't too bad this time around. On my last run I got the timing right to slide around that corner using the e-brake, I wish I did another serious run to see if that would end up helping or hurting my times. I vote for Brian to enter the permanent rotation of co-chairs/course designers ![Big Thumb](https://www.tamparacing.com/forums/images/smilies/bigthumb.gif)
I like the idea of FTD getting a donut, it will add more of a competitive spirit to SR events, which everyone says is lacking. This should become an SR tradition...I for one really wanted that donut and will spend my time during the off season meditating and thinking zen thoughts about my suspension.
Loren, what were your impressions of the s14? Did anything really seem lacking in a 'damn if only this car had.......' kind of way? Other than the presence of power steering of course.
...and props to mattback, I missed the majority of his time on course, but caught some good drifts of his.
I don't see any results on the sunriders website, can somebody post a direct link? I think there's some IE only shenanigans in that web-design.
http://www.sunridersautocross.com/sr...v03ByClass.pdf
I think I er ummmm, I mean the dog took a bite outta that doughnut oh yeah thats it! the dog...
Is anyone else having problems getting the results? Give me some more feedback if you are. As in, what's the problem, what browser are you using, etc. I can bounce it off the webmaster and see if there's anything we can do. Probably don't need to clutter the forum with that. Just sent me an email.
![](https://www.tamparacing.com/forums/signaturepics/sigpic13272_2.gif)
Originally posted by Loren
[B
It seemed to handle quite well overall. I could probably do without the power steering, or at least find some way to tighten things up and make it more responsive. Stiffer springs? Swaybars? It seemed a little sluggish coming out of the turns, (that's saying a lot coming from a Miata guy!) a little more power would be helpful. And, of course, tires would help A LOT. I'd do that first.[/B]
[B
![Smilie](https://www.tamparacing.com/forums/images/smilies/smile.gif)
I've actually got my eye on a set of cams when I'm done with my suspension, not sure what I am going to spend money on after that though...springs and swaybars i should have pretty soon. I'm also planning on replacing all the suspension bushings and going with pillow ball where available (and affordable). I don't think i can live without my power steering though...not yet at least, maybe when I can get another car to use for daily driving.
I also hope to have a dedicated set of wheels for autocrossing next season, sheathed in Azenis of course.
i started out ds'ing into 1st on that tight corner toward the end of the course and with my traction impaired car/short gears figured it out really quickly that 1st gear was not the right move. I def need some better tires...the Pirellis were not cutting it. was having traction issues the entire way through the rear straight/slalom. helluva lot of fun and i cant wait for the next one.
1995 BMW 540/6 - The Track Rat
2009 Ford Escape - Stock Toy Hauler/DD
2007 Lexus RX350 - Stock Wife Hauler
2009 Kosmic - The Toy - 125cc Vortex Super Rok TAG, (For Sale - $2800)
2007 Intrepid Silverstone - The Faster Toy - CR125 6-Speed
Originally posted by OversteerS2K
For the postage stamp lot you had to work with, Brian, it turned out well. It certainly was a challenge when combined with that sealer. I slid all over hell. Well, every RWD did. And the 1st gear issue went away for me...I just let it crawl out of turns in 2nd.
It looked like a whole lot of drivers got better at the transition from a 50 MPH sweeper to a first gear, tire smokin', hairpin.
There needs to be a drift event there. Every time I blew a run I just tried to slide the back end as much as possible.... I see why that stuff's gettin' trendy - it's fun. How do you score a drifting comp. though? "Style" points? It's definitely NOT the fast way through 75% of those turns today.
When I eventually get some more memory and a capture card I'll send Loren some video. I taped several Miata's, the 540, M-3 Conv., the Stalker, the drifter 240, and some slow brown Datsun
. You'll get your revenge next weekend where all my mistakes will cost seconds, not tenths.
And there really isn't much grip to be had out at SPCC, anyway.
Sealed asphalt is an "entertaining" surface to drive on.
they are pirelli p-zero rossas. i was running them @ 42psi and they have probably about 1500 miles on them. I had Toyo t1-s' previously and the Pirellis really just don't compare. Next set of tires i get will most likely be some azenis' though.
I enjoyed the sealed asphaly though... power on oversteer was my friend in several cases.
my fronts are toyo fz4's....i was just having traction problems under acceleration.
