FS:kicker kx600.1 amp
this is BRAND NEW. NEVER USED. worth $600 plus tax in the stores brand new. selling for $400. comes with all accesories
FEATURES
-Class D design
-frequency response 20-200 Hz
-300 watts RMS x 1 at 4 ohms
-600 watts RMS x 1 at 2 ohms
-MOSFET power supply
-variable low-pass crossover 50-200 Hz at 12 dB per octave
-KickBass provides up to 18 dB of boost at 40 Hz
-switchable subsonic filter 25 Hz, 12 dB/octave improves efficiency by eliminating low frequencies below the range of human hearing
-preamp- and speaker-level inputs
-preamp outputs
-Amp-Strapping circuit allows two KX1200.1 amps to be joined to produce double power (must be connected to a 2-ohm load)
-fan-cooled
-dimensions: 16-1/16"W x 2-9/16"H x 10-5/16"D (with shroud); 13-3/8"W x 2-3/8"H x 9-9/16"D (without shroud)
FEATURES
-Class D design
-preamp outputs
-fan-cooled
PLAY PAINTBALL LOCALLY
http://www.blitzkriegpaintballfield.com
^^^^^^Click There^^^^^^
Modified Racing Inc.
(Blown99civicSi)
John Solaro
https://www.tamparacing.com/forums/h...t=john+scammer
https://www.tamparacing.com/forums/h...acing-inc.html
John Solaro
