same subs. 400 to 2 or 800 to one of them, which is louder
Old Jan 18, 2003 | 07:26 AM
2qk4u's Avatar
Default same subs. 400 to 2 or 800 to one of them, which is louder
what would hit harder.
pushing 400 to 2 subs or 800 to 1 of them?
Old Jan 18, 2003 | 07:29 AM
93ex's Avatar
Just Ledoux it!
in theroy 400 to 2
but it depends on the box etc blah blah
Old Jan 18, 2003 | 09:17 AM
naciamaj's Avatar
MY LIFE, YOUR VACATION
It depends on how much watts the subs can handle. What you could do is bridge them, which is to take both pasitive and negitive wires that are coming from the subs and tie the pasitive to the positive and the negitive to the negitive, then put the positive wires and put them on one connector and then take the negitive wires and put them on the opposite side. Doing this will give you the most out of your amp.
Old Jan 18, 2003 | 10:06 AM
93ex's Avatar
Just Ledoux it!
translation:
run your subs in parallel to show a 2 ohm (if 2 4 ohm speakers) to the amp, increase souput makes amp work arder
Old Jan 18, 2003 | 10:35 AM
naciamaj's Avatar
Yeah thanks for the translation, I know the way that I said it was kind of confusing.
Old Jan 18, 2003 | 09:55 PM
2qk4u's Avatar
i am no fool.
my subs are dvc 2 ohms
if i bridged them in my 2 ohm stable amp it would drop it to 1ohm and cut off like a motha
i have 1 sub on each channel
i am running 400x2@2ohms or 800x1 bridged@4ohms
or i could wire each coil of 1 subwoofer to each channel of the amp and push 400 to each coil thus giving 800 watts to my 1 woofer
Old Jan 19, 2003 | 07:59 AM
93ex's Avatar
Just Ledoux it!
dvc 2 ohms
2 2 ohm voice couls, or 2 4 ohm voice coils
Old Jan 19, 2003 | 01:53 PM
2qk4u's Avatar
dual 2 ohm coils.
i have 2 hookups on each speaker.
i have them daisy chained to each other and then run into 1 channel on the amp.
