Alpines Vs. OEM Equipment
E & I Certified
on
I had some 5x7 Alpine Type-S speakers I found in one of my mustangs, so I decided they had to be better than the 6x9 factory speakers in my Dodges front doors...NOPE!
Well I ended up putting the cheap old factory Dodge speakers back in.. the Alpines sounded a hint more clear, but they sounded like crap when any amount of Bass went to them.. are they blown ? cheap? or is it the head unit doing that ? The head unit is also factory, but getting replaced next month.
I would say probably the radio... is it in anyway amped??
I had a set of Alpine Type S 5x7s in my old expedition and they sounded horrid with the stock radio.. had to max them out to make them even sound good..
Up graded to a after market radio and then turned on the high pass on the radio and they screamed..
and getting bass out of a 5x7 speaker is bad as it is.. get a sub if you want good bass response..
E & I Certified
on
perhaps I will try them again when I upgrade the stereo.
The Alpines are reading 8 ohms on the bench test.
How were they mounted?? Obviously the 5x7's are smaller than the Dodge openings, so were they well sealed all around? Are you certain you wired them in polarity?
Luke
Audio Expert
11203 49th St. North Unit A3
727-573-2626
www.audioexpertonline.com
Audio Expert's Facebook site
Luke
Audio Expert
727-573-2626
You should be able to get OK midbass response out of 5x7s, with that said, Luke is probably on the right track. Yet again they are type-s and everytime I heard them I wanted to cover my ears and run.
Need anything installed or built? PM me.
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Tweets: Image Dyamics CD1pro mini horns
Mids: Sundown Neo Pro 8s
Amp: Kicker IX500.4 (2)
Sub Stage
Subs: (2) Dayton Audio 15" HF
Amp: Kicker IX1000.1
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Sub Stage
