build.
cutting a circle with a jigsaw simply erases any weight your words carry against someone else not using the correct tools for a job.
you know.. pot, kettle... fail boat.
a passion for audio. do it right the first time.
Taz Devil Customs
2000 Nissan Maxima, 3L
Hertz HSK 165 XL - 2 pairs
Hertz SPL SHOW 8" - 1 pair
Hertz EP-4 - mids/highs amp
Power Acustik BAMF 5500D - sub amp
Digital Designs 9518 - MONSTER
Taz Devil Customs
your inability to see the relation of failing to cut a circle and failing to cut a 45 degree angled piece is astounding. do you happen to drive a certain short bus?
Taz Devil Customs
Taz Devil Customs
you would probably lick the windows if they were sugar cubes too wouldnt you?
Taz Devil Customs
Taz Devil Customs
ok, so here you go. your irregular shape that you mounted a sub to is directly correlated to the 1x2 that he used as a corner brace.
dont talk till u get that dick out of your mouth. its rude to talk with your mouth full.
Taz Devil Customs
Taz Devil Customs
that picture was just a machup, this box has to built in the car, ever piece cut and fit, from that picture it still had to completly come out of the car so the 2 6" aero ports to be cut thru rear deck, as of now it is done, yes all corners are reinforece with 2x2, siliconed and installed, as to the jagged edge, well it a compound miter cut and had to be timmed to fit that double baffled panel, it was cleaned up nice and striaght, i still have to do cosmetics (fleece, glass, and carpet) and build floating amp rack for the 2 3k mono amps. i have 14 hours in rewiring this 30 speaker install, carputer, radio, 8 cross overs, 2 4 channel amps, head unit, lcd screen in dash, then the time it took to fit 2 6" aero ports, their opening size is 9", box fit, installed glued, screwed, siliconed, customer needed the car for a trip, will be back in 2 weeks to finish, at least he had mids.highs playing. CANDYPANTS when you have a build equal to this please post your inprogress pictures
he'll talk shit anyways though.
Taz Devil Customs
Taz Devil Customs
your intelligence might have been left in the classroom...while you brought your haterade with you.
