dual 1 or 2 ohm?
Old Jul 11, 2010 | 07:09 AM
aids@ftl's Avatar
Default dual 1 or 2 ohm?
what is the difference... pros and cons plz .. im so lost lol never realy heard of dual 1 ohm
DuBsTeP = LiFe
I like my cars clean
But my ladies CLEANER
Old Jul 11, 2010 | 07:19 AM
the727kid's Avatar
Really just depends on what amp you want. One isn't better than the other. Although for SPL high powered applications, Dual 1 may be the way to go because you can drop it to .5 ohms.
Need anything installed or built? PM me.
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Tweets: Image Dyamics CD1pro mini horns
Mids: Sundown Neo Pro 8s
Amp: Kicker IX500.4 (2)
Sub Stage
Subs: (2) Dayton Audio 15" HF
Amp: Kicker IX1000.1
Old Jul 11, 2010 | 08:44 AM
NT_Hardcore's Avatar
bassheadsent.net
its just to offer diff wiring options depending on what ohm load ur amp produces the most power.
http://www.bassheadsent.net/
Old Jul 13, 2010 | 04:31 AM
aids@ftl's Avatar
Thanks guys
DuBsTeP = LiFe
Old Jul 13, 2010 | 05:13 AM
mikiemike75's Avatar
mikiemike75
one other thing to think about also is the higher ohms the more clarity you will have... not as much boom but it will be a little more chrisp... what amp are you running ??? dual 1 you can bump up and run in either 2ohm or drop it down and run in .5 ohm... 2ohm you can run in 4ohm a little more clarity or you can drop it down ta 1ohm... so just depens on what your looking for... not sure how great you are but always remember you can bump the ohms up or down... it will always be half of the 2 added together... exm dual 4 will either be 8ohm or droped down to 2ohm... what are you looking to run ???
Built By:Mike Carpenter @ Overdose Performance in Ocala,Fl...
Tuned By: Tony Gannon @ Hp Performance
hp~5!! trq-4!!
doing work!!!!!!
Old Jul 14, 2010 | 05:07 PM
aids@ftl's Avatar
https://ssl.perfora.net/www.ficaraud...iew.shopscript
its the 18... im not sure what amp yet
DuBsTeP = LiFe
