small 4th order build for myself..
i forgot the specs.. heres the pics i got for now more to come after i finish it tomorrow..
starting with the sub going in it..
im not happy with this.. few last things i had to do turned out like crap! o well i hope it works.im unhappy with it cause you can see the baffle is cracked.. and there was a gap so i spray foamed it hope that works
sub stage. 4 american bass XD 15's
sub amps. 2 audiopipe APSM1500's
mid's. 16 american bass SQ 6.5's 8 pyle pro super tweets
mid's amps. 2 autotek ATX3000.2 and 1 autotek ATX950.4 on the tweets
dude, i understand you want to show off your work, but take 5 mins and pick up your yard, and use a table to work off of not the ground, it makes it much easier, predrill your holes when using drywall screws, wood wont crack!
i predrilled all the screws.. i think what happend was i got that screw to close to one side of to close to the edge
it looks like you go around the neighborhood and steal kids toys, inflatable pools and painting supplies on a regular basis.
Is that the fundage for your projects? lol.
Did you ever get that truck interior finished?
truck? nope and the inflatable bouncy thing is my sisters for her 2 kids..
splitting your wood, you are either drilling a to small of a hole or not deep enough, for most boxes a 1 5/8 screw will work. The screws just hold it together until the glue dries. try putting some glue on the screws (this will help them lube in but a bitch to come out, or use a bar of soap, scrape screw on it b4 put it in the hole.
nice thanks for the info.. im going to fiberglass the baffle in ( talked to a few people over on floridaspl and they said fiberglassing it in should do the trick ) i think it should be fine i tried to take it out today and it wouldent budge.. so im going to fiberglass it in from both sides and then i got to get some kind of thing for the removeable acess panel to change sub out if it blows. i guess mill have to get some treaded inserts
ok well it took some convinceing with a hammer to get this baffle out but i took the front off and took the baffle out now i got to sand all the glue off.. this glue is some strong stuff! i didnt have the extra cash to go with fiberglassing it so im just going to rebuild the baffle and put 2 screws in each side.. only the one side cracked it had 4 screws in it.. so this one should come out better.. heres pics for now..
