porting through the rear deck....
Old Jan 29, 2010 | 07:18 PM
Santos's Avatar
Default porting through the rear deck....
is it as simple as it sounds and what do you guys think about it?
TR "Old Skool" DA member #60
Santos618 - Xbox 360 gamertag
GTA4
Forza 4
Madden 12
open to any good online games, i just suck at shooters lol
Old Jan 30, 2010 | 02:48 AM
alphabets's Avatar
I ♥ ♫
For loudness, sure.
Quality, no.
lol, internet.
Old Jan 30, 2010 | 05:09 AM
luke81's Avatar
Yes and no, with some explanation. I do not like to run the actual port from the box into the rear deck in most applications. As alphabets said, i think quality suffers. You're losing a certain level of acoustic coupling between the port and woofers, unless the rear seat is removed and the woofers are exposed into the cabin. The amount is slight, but in some applications it will still hurt.
In a situation where the trunk is tightly sealed from the car I like to do a normal ported box facing rear, and remove a portion of the rear deck to allow bass into the car.
In most cars where the only thing separating the cabin from the trunk is a foam seat and some carpet trim panels there's nothing to be gained by doing anything.
Luke
Audio Expert
11203 49th St. North Unit A3
727-573-2626
www.audioexpertonline.com
Audio Expert's Facebook site
Old Jan 30, 2010 | 02:25 PM
Santos's Avatar
ok...i was thinking of doing this to the accord (4dr) i have heard some before and you can feel the bass from outside the car...well if its not worth it then i guess one 12 hooked up right will have to do.
GTA4
Forza 4
Madden 12
