help with highs
Old Jan 20, 2010 | 09:13 PM
dave_rx's Avatar
Default help with highs
looking for 8s or 6 1/2 need something loud and clear
what will be a
good idea to use lmk.... I will be running
150 rms to them
they will be in my doors..... lmk
trying to make a componet set with them
and a set of nice tweeters...
Old Jan 21, 2010 | 07:28 AM
kpr10is's Avatar
Maximaniac
What kind of vehicle is this going in?
What else is already installed or will be installed in said vehicle?
Do you have a budget?
It sounds like you want to piece the mids and tweeters together individually instead of buying a component set, which will work, but do you have a need to do so?
What have you had in the past as a comparison?
What is your idea of loud and clear?
Are there a lot of subs they'll have to keep up with or will they be doing midbass duty? Which also relates to whether you'll need/want 8's or not...
These all would help. There are a million brands of speakers out there, and hence a million people will tell you their opinion, which may or may not sound good to your ears.
Old Jan 21, 2010 | 08:26 AM
dave_rx's Avatar
subs are mtx 9500 12s..... there's nothing in truck....
2006 dodge Durango there is a budget but don't
want to get garbage. loud and clear not wanting to put
sirens in the grill and 30 6 1/2s in each door.... lol
I have seen and heard the tweeters I want there the
earthquake screamers nice small and flush mount and 150 rms
...what I'm trying to do is to build my on comp. set
trying to combine the best twetter to the best mid so I can
get the best of both worlds....
Old Jan 21, 2010 | 10:53 AM
Taco15's Avatar
you could try some o2's they freakin scream and are pretty reasonable. I suggest having a proffesional install the tweeters since they are sensitive as hell. If you dont know what you're doing you could mess them up just by putting the wires in the terminals.
i did it 2 weeks ago and had to tear them apart to resolder the leads.
Old Jan 22, 2010 | 10:12 AM
1stGen7's Avatar
layin frame for life
high joes sells the O2's and soundstreams also i think they got a few outhers there also
sub stage. 4 american bass XD 15's
sub amps. 2 audiopipe APSM1500's
mid's. 16 american bass SQ 6.5's 8 pyle pro super tweets
mid's amps. 2 autotek ATX3000.2 and 1 autotek ATX950.4 on the tweets
