Wiring Help
Old Oct 13, 2009 | 11:43 AM
Taco15's Avatar
yes. run the power and remote on the same side. run your rca's on the other side.
what kind of CDP is it? usually its the light blue or blue with white stripe. solid blue is power antenna.
Old Oct 13, 2009 | 01:45 PM
Define's Avatar
Yeah, they said what they do on the wires, so I spliced it into the Antenna one. I got everything done, hooked it up... and found out my amp was blown =D
But i'm getting a 1100 watt tomorrow. But anyways, Thanks ALOT for all the help, finally got it done.
Old Oct 13, 2009 | 10:51 PM
Kyleisme's Avatar
what makes you think your amp is "blown"
Old Oct 14, 2009 | 05:08 AM
luke81's Avatar
If the deck has separate antenna and amp turn on leads your amp is only going to turn on when the radio is on as it is now, but some decks use the same lead for both. In that case, you're good.
Luke
Audio Expert
11203 49th St. North Unit A3
727-573-2626
www.audioexpertonline.com
Audio Expert's Facebook site
Old Oct 14, 2009 | 05:11 AM
Taco15's Avatar
agreed. My eclipse remote wire wire came loos and unreliable so i hooked it up to the red 12v. still works just fine.
let us know if we can help anymore!
Old Oct 15, 2009 | 11:55 PM
Define's Avatar
SPeakers started cutting in and out, and it started smokeing, it's a OLD ass Jensen 600 watt. I got a Autotek 1000 watt with 2 MTX Jackhammer 12's. It's a banging ass system
Old Oct 15, 2009 | 11:57 PM
  #17 (permalink)
Define's Avatar
I'm ALL Done, got it all set up, i REALLY appreciate the help =). Definately couldn't have done it otherwise.
