Radio turns off at high volume
So When i turn up my radio it tends to shut off but like 2 seconds after that it turns back on and if i dont turn down the volume it keeps doing it
I have 1 12' sub and a 600 watt amp
anybody know the reason
What kind of head unit is it? If it's a double DIN, any kind of flip out or high-output you may need to run a ground wire to the frame or body. You may have already fried the traces by now, but hopefully not. Is there an inline fuse on the 12v positive lead on your wiring harness? Check that too.
lol, internet.
+1
I had the same issue. My radio was shutting of because a bad ground from my dash , it was sucking up all the juice from my radio. I found the loose ground, tightened it and all good.
seems lihe you just have a bad radio ground or possible issue like mine.
