System without head unit?
if you want it done correctly - that is the best way, gives you a volume knob, cross over and eq, with proper line voltage. With the compression used in ipod software, being able to adjust the sound with the eq is the only way to get great sound!
Why not a HU in the glove box or center console?
Need anything installed or built? PM me.
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Tweets: Image Dyamics CD1pro mini horns
Mids: Sundown Neo Pro 8s
Amp: Kicker IX500.4 (2)
Sub Stage
Subs: (2) Dayton Audio 15" HF
Amp: Kicker IX1000.1
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Sub Stage
I've done this in quite a few older/antique cars. Put the HU under the seat or in the trunk, pick up an IR remote eye (couple different company's make them for HU's) and program it to the HU's remote...mount the eye somewhere inconspicuous (sp?) and you're set. Then you'll atleast have a power source, volume control, eq, etc.
