Battery/Cap ?
Old Apr 24, 2009 | 04:40 PM
JoeDeal's Avatar
Default Battery/Cap ?
I have a optima red top im using for my stereo system. I have a Clarion DPX 11500 Amp which is somewhat of a power hog along witha kicker 4 channel amp. My problem is I really have no room for the battery. Would a power cap b alright for the 2 amps I have if so how many farad should the cap be? Any help is appreciated
Old Apr 24, 2009 | 05:12 PM
kpr10is's Avatar
Maximaniac
Short answer, no a cap will not be alright. Upgrade the big 3 wiring in the engine bay and think about an alternator instead if you are still having troubles.
Old Apr 24, 2009 | 08:50 PM
JoeDeal's Avatar
Im not haveing power trouble with the xtra battery, but if I get rid of the xtra battery and get a cap I will run into power issues? How much are the aftermaket alternators roughly and how many amps are they? My factory alternator is 90 Amps
Old Apr 24, 2009 | 09:49 PM
Notladstyle's Avatar
King of Ricers
make sure to subtract what your engine/car actually use from that 90 amps. My engine 6cly draws 11 amps without the coils firing.
And at cruising speeds (2000-2400rpm) your alternator produces slightly more than half of that rating.
notladstyle.blogspot.com
Old Apr 25, 2009 | 12:33 PM
pnrcaraudio's Avatar
Default My Opinion
I would personally recomend doing the Big 3 like mentioned above and then find a smaller in size specialty battery like Stinger or Kinetic.
Both Stinger and Kinetic have batteries just as good as an Red Top in about a 1/3 of the physical size
