Anyone built a blow through ?
Old Apr 8, 2009 | 10:01 AM
NT_Hardcore's Avatar
bassheadsent.net
i personally have never boxed one in so i cant say its better/worse than the accordian boot. i wouldnt do any half assed work on someone elses car, but the fact that i cant weld is my decision maker...
http://www.bassheadsent.net/
Old Apr 8, 2009 | 06:49 PM
MCOR's Avatar
I have to admit we have never welded one in either. Being a 12 year Master Tech for Ford Motor Company and knowing how differently the box flexes from the body, I would definately not want to weld the two together. We usually loosen the bed and slide it back (no more than 8 torx bolts most of the time) to make plenty of room, then run a silicone bead on both ends of the seal, screw it into the body and the bed, seal each of the screws in also, then slide it back together. I have NEVER had one return with a leak. This method was suggested by our wholesale rep at Topper King in Brandon, and it has never failed yet!
And yes, this is Land O Lakes where rednecks double their pickups as submarines!
Matt-check out these deals: https://www.tamparacing.com/forums/m...ood-stuff.html
MCOR Automotive LLC
mcorautomotivellc@verizon.net
www.mcorautomotive.com
1635 Dale Mabry Hwy Ste 3
Lutz, FL 33548
(813) 362-5454
"TR Official 12V Shop"- Automotive Audio/Video/Security (JL Audio, Alpine, Hertz/Audiosn, ARC Audio), Window/Tail Lamp Tint, Custom Wheels, Clear Shield, automotive upholstery and leather conversions, "All the Above!"
Old Apr 9, 2009 | 05:06 AM
luke81's Avatar
I've also never welded one, and certainly don't plan to. Even my little ranger can flex the bed incredibly far if I park it on a crooked hill or something. If the cab and bed can't flex it's going to redirect that stress somewhere else on the truck and twist the whole body. I've usually just shot glass adhesive on as a sealer and attached the boot, no problems.
Luke
Audio Expert
11203 49th St. North Unit A3
727-573-2626
www.audioexpertonline.com
Audio Expert's Facebook site
Old Apr 18, 2009 | 09:37 PM
93LowBody's Avatar
TR Balla Donor Supreme
Thanks for all the info.. im gonna start collecting stuff to do this.
Gonna get all the subs and stuff together first before i start this.
Not sure what to go with though, my last system was 2 kicker cvr 12s and kicker 750.1 amp that did 138db.. and sounded good overall. May go with kicker stuff again idk.
