amp problem
everythins connected right... theres powwer there is ground and to the dc plaer and the rca's .... idk whats wrong?? can you run all the wires thru the same side or do the rcas have to be on separate side?
as long as you wires carrying the sound are shielded there should be no problem, if they are not you might get a hum.
if nothing is working then it sounds like you either A have a wiring problem or B have a bad unit somewhere, may it be your head unit or amp or C something random and wrong
if your 100% convinced it is not a wiring problem (answer A) then check all the fuses anyway just incase
now another set of questions
does nothing work (no sound/head unit doesn't turn on light up)
or
did you try to add an amp to power some extra speakers and those do not work?
or
Is your remote wire connected?
Need anything installed or built? PM me.
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Tweets: Image Dyamics CD1pro mini horns
Mids: Sundown Neo Pro 8s
Amp: Kicker IX500.4 (2)
Sub Stage
Subs: (2) Dayton Audio 15" HF
Amp: Kicker IX1000.1
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Sub Stage
