BIG 3?? help
Old Mar 27, 2009 | 07:23 PM
AaronBlackmon's Avatar
Default BIG 3?? help
how much would you charge
to do the BIG 3 upgrade on my car?
99 Sonoma
Old Mar 27, 2009 | 08:18 PM
Kyleisme's Avatar
727kid did it for $20... great job too..
Old Mar 27, 2009 | 08:55 PM
JoeDeal's Avatar
Here's a link with pics if u wanna DIY http://forum.sounddomain.com/ubbthre.../312025/page/1
Old Mar 29, 2009 | 07:30 PM
Mafiakiller's Avatar
Ballin Beretta
is this really helpful? or pretty much anyone would recommend to a person that has a system?
Old Mar 29, 2009 | 08:28 PM
Kyleisme's Avatar
the only ones that will make a difference if you have a stock alt is your grounds.. batt ground and engine block ground.. the alt already has wire matched to its output so unless you upgrade it, its not needed nor will it change much unless its a lot shorter..
Old Mar 30, 2009 | 11:05 AM
GradeA_TireFryer's Avatar
All American, rice eater!
you should always upgrade the ground (at least from battery to frame) when running a power wire for a amp(s) with same or larger than the power wire.
Old Mar 30, 2009 | 05:11 PM
Ballin Beretta
aight cool
