trunk\box
Old Mar 6, 2009 | 08:22 AM
Mafiakiller's Avatar
Ballin Beretta
Default trunk\box
what kind of box sounds the best in a reg. trunk?....either though it will sound like shit no matter what on the outside..unless there is a way to prevent the nasty rattling sound?
Old Mar 6, 2009 | 08:36 AM
GradeA_TireFryer's Avatar
All American, rice eater!
bandpass and port thru rear deck! (or fold down armrest if you have one.) put the sound where you can hear it!
Old Mar 6, 2009 | 09:00 AM
Notladstyle's Avatar
King of Ricers
rear facing SEALED box sounds BEST.
rear facing bandpass sounds LOUDEST.
If you want to get rid of the rattling, you pretty much have to remove hte entire spring assembly from the trunk as this is what is making the noise.
notladstyle.blogspot.com
Old Mar 6, 2009 | 10:29 PM
the727kid's Avatar
There really isn't a true anwser to this. Theoreticly a bandpass design would sound the best or get the loudest.
Need anything installed or built? PM me.
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Tweets: Image Dyamics CD1pro mini horns
Mids: Sundown Neo Pro 8s
Amp: Kicker IX500.4 (2)
Sub Stage
Subs: (2) Dayton Audio 15" HF
Amp: Kicker IX1000.1
Old Mar 7, 2009 | 08:29 AM
DaMF'inBoss's Avatar
Holy SHIT , before you do that check to see what is "Rattling" and add some sort sound deading material to it.
A whole lot of thangs that go BANG!!!
Old Mar 7, 2009 | 09:14 AM
Kyleisme's Avatar
a bandpass firing forward or through rear deck will work wonders.. you can't hear much outside when the windows are up..
Old Mar 7, 2009 | 06:12 PM
MCOR's Avatar
[quote=Kyleisme;6390076]a bandpass firing forward or through rear deck will work wonders. quote]
+1. If you have the time and the patience, you will get incredible sound if you port the subs up through the rear deck. But the most common is subs just firing rearward in a sealed or ported box for the reasons mentioned above.
And all rattles can all be fixed. It just takes time to clean them all up. It is not uncommon to even have to completely remove a rear bumper to seal up all rattles behind it. Nothing worse that a jam up system that rattles so much you can't even appreciate the music...
Matt-check out these deals: https://www.tamparacing.com/forums/m...ood-stuff.html
MCOR Automotive LLC
mcorautomotivellc@verizon.net
www.mcorautomotive.com
1635 Dale Mabry Hwy Ste 3
Lutz, FL 33548
(813) 362-5454
"TR Official 12V Shop"- Automotive Audio/Video/Security (JL Audio, Alpine, Hertz/Audiosn, ARC Audio), Window/Tail Lamp Tint, Custom Wheels, Clear Shield, automotive upholstery and leather conversions, "All the Above!"
Old Mar 9, 2009 | 05:14 AM
luke81's Avatar
It's also going to vary with your sub. Post up what you've got and that will help too. And the rattling on the outside can be a pain to stop totally, but it's possible for sure. Be prepared to take apart your car and tighten each spot where one part meets another.
Luke
Audio Expert
11203 49th St. North Unit A3
727-573-2626
www.audioexpertonline.com
Audio Expert's Facebook site
Old Mar 9, 2009 | 11:40 AM
i dont understand the big deal if the car rattles on the out side!, if cant hear it driving down the road (windows up ac on, it is florida) who cares!!!!!!!!!!!!!!
