Audio GURUS
Old Feb 23, 2009 | 01:05 PM
BtZ..AcCord's Avatar
Default Audio GURUS
I got a problem i just got a Pioneer headunit from a friend of mines i had it in the car for a couple of weeks worked fine......then i hit a huge bump and it just shuts off.I've checked all the fuses none blown and even connected the headunit to a battery and it turns on and did that red and yellow wire thing and it works.But when i connect it normally from harness to harness it doesn't work!
What can be the problem here i need music!
Old Feb 23, 2009 | 08:12 PM
the727kid's Avatar
Could be wiring of the actual car. I would first make my own solid ground. Then run your own main line to the battery and tap in the acc wire from under the dash.
Need anything installed or built? PM me.
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Tweets: Image Dyamics CD1pro mini horns
Mids: Sundown Neo Pro 8s
Amp: Kicker IX500.4 (2)
Sub Stage
Subs: (2) Dayton Audio 15" HF
Amp: Kicker IX1000.1
Old Feb 24, 2009 | 05:23 PM
kapone's Avatar
technician ...
what he said ^.... while your at it you can upgrade the power wire to the deck ( yellow) to like a 10 gauge wire power and ground every little bit helps sound quality ...
Originally Posted by George Orwell 1984
Its presupposed that somewhere or other, outside oneself, there was a "real" world where "real" things happened. But how could there be such a world? What knowledge have we of anything, save through our own mind? All happenings are in the mind. What ever happens in all minds, truly happens.
Originally Posted by Funk
Your mind contains the whole universe, the key is being able to see past yourself, this world, and thought itself.
Old Feb 24, 2009 | 05:32 PM
How can i make my own ground do i use the cars wiring for the radio? i have no idea about this stuff..if i can't do it i'll just bring it to a audio shop
Old Feb 25, 2009 | 09:52 AM
Got it working!!! ended up finding the blown fuse didn't look too good the first time so yeah got my music back!.....
