no bass outta front speakers
Old Dec 8, 2008 | 07:26 AM
freakasis's Avatar
Default no bass outta front speakers
i tried differant speakers and get nothing, only high pitched sound comes through, nothing fancy installed just a sony deck and aftermarket speakers. could bad wires cause this? i looked through all the settings on the stereo and everything looked fine. i balance it to the front, no bass, i balance it to the back, i get bass. WTF?
"Black people can't be racist" - Some black guy.
Old Dec 8, 2008 | 09:49 AM
luke81's Avatar
What kind of car? You could have the one of the fronts' polarity backward, this causes a huge loss in bass.
Luke
Audio Expert
11203 49th St. North Unit A3
727-573-2626
www.audioexpertonline.com
Audio Expert's Facebook site
Old Dec 8, 2008 | 10:36 AM
freakasis's Avatar
92 civic, i will check the wires tomorrow, is the big or small one on the speaker positive?
Old Dec 8, 2008 | 05:18 PM
MCOR's Avatar
The larger terminal is the positive. If you have one side hooked up with the correct polarity and the other side hooked up opposite, you will get no bass. Also, be sure there wasn't a component crossover in there at one time that is still connected...
Matt-check out these deals: https://www.tamparacing.com/forums/m...ood-stuff.html
MCOR Automotive LLC
mcorautomotivellc@verizon.net
www.mcorautomotive.com
1635 Dale Mabry Hwy Ste 3
Lutz, FL 33548
(813) 362-5454
"TR Official 12V Shop"- Automotive Audio/Video/Security (JL Audio, Alpine, Hertz/Audiosn, ARC Audio), Window/Tail Lamp Tint, Custom Wheels, Clear Shield, automotive upholstery and leather conversions, "All the Above!"
Old Dec 8, 2008 | 06:15 PM
freakasis's Avatar
ill check em out tomorrow if i have time. i know i had it playing with the left side unhooked and it still had the problem, so does that mean that it has to the be right side thats backwards? and ive been all around under the dash i would have seen a crossover right?
Old Dec 9, 2008 | 05:43 AM
TJElite's Avatar
Comparing bass out of front speakers, which are usually in less than stellar baffles (doors) to rear speakers is a loser bet...the rears, usually in bigger, better sealed areas (like a trunk) will almost always win. And they are usually bigger.
Pull the door panel off...see all those holes? Anytime sound can get from the back of the speaker to the front, bass will suffer from the cancellation (rear wave is out of phase with the front). Same problem you get when one speaker is out of phase. Get some dynamat or something similar, seal all the holes, and the bass will improve.
Also, factory crap speakers often sound 'bassier' to a point, because they are made of cheaper, lighter material, that makes them more efficient.
Toby
Toby Johnson
BlackDog Racing
BlackDog Speed Shop
Lincolnshire, IL
Old Dec 9, 2008 | 06:15 AM
freakasis's Avatar
theyre not stock speakers theyre pioneer, and its not that the bass sucks its that there is NONE! like the woofer part the speaker doesnt even move, all the sound is comming outta the tweeter. thought it could be bad speakers so i changed them and have the same problem. im gonna be testing the polarity and resistance of the wires later today if i have time.
Old Dec 9, 2008 | 06:58 AM
luke81's Avatar
Ok, if they're not moving at all then something upstream is taking the bass out of the line. Look for a crossover in the speaker line someplace, or even just a bass blocker.
Luke
Audio Expert
727-573-2626
Old Dec 9, 2008 | 07:59 AM
freakasis's Avatar
it would be noticable right? like a box or somthing? not somthing so tiny i would never see it?
Old Dec 9, 2008 | 08:05 AM
Notladstyle's Avatar
King of Ricers
a tiny capacitor would do it. You said your tweeters are making sound but your midrange isnt - are you sure you didnt hook the lead cables to the tweeter lead on the speaker?
notladstyle.blogspot.com
