Need Some Help
Old Nov 2, 2008 | 08:07 AM
IWANNASUPRA's Avatar
Default Need Some Help
so yeah iam not an audio person but ive hooked up a couple and i just installed a new alpine ipod only head unit in my dd its a 95 monte carlo and when the unit is on my speedo bounces around crazy and when i turn the unit off speedo works fine a buddy of mine said it could be feedback in the ground idk any input would be greatly appreciated
Old Nov 2, 2008 | 10:44 AM
kapone's Avatar
technician ...
your friend could be right... I would rewire the deck. New power wire strait from the battery, (I have 10 gauge running to my deck) and that should solve your problem...
Originally Posted by George Orwell 1984
Its presupposed that somewhere or other, outside oneself, there was a "real" world where "real" things happened. But how could there be such a world? What knowledge have we of anything, save through our own mind? All happenings are in the mind. What ever happens in all minds, truly happens.
Originally Posted by Funk
Your mind contains the whole universe, the key is being able to see past yourself, this world, and thought itself.
Old Nov 2, 2008 | 02:52 PM
GradeA_TireFryer's Avatar
All American, rice eater!
you dont have to run a power wire from your battery, first run a new good ground wire from a good metal mount, then check your resistance with a meter from battery to ground and fram ground to engine - correct any resistance that is there and you should be good. I bet you have a ground issue - and your factory radio was grounded thru the antennea which is not good enough now.
