Stereo & Electronics Upgrade in the D/D!
Okay, so you may remember this thread:
https://www.tamparacing.com/forums/a...o-install.html
This was a self-install of the stereo components that I had bought for my DD. Well it was all fine and dandy, except that the stereo would cut out from time to time, and there were wires EVERYWHERE for my electronics gear (Nav, Cell Charger, Blue Tooth Charger, Radar & Laptop). Not to mention that I had my bass knob just tucked between the driver's seat and the center console. So of course, I'm OCD, and that shit got to me!
Not only that, but I was driving down the road and my truck completely shut off one day, and I had no power. I was like WTF?
So I had just recently met the guys over at MCOR Automotive on US41 just north of SR54... So I made the call & Matt got me in that Saturday to get things diagnosed, fixed, and cleaned up!!
Here are some Before & After Pictures:
Here you can see the wires everywhere in the center console area...
Now it's all cleaned up! The tri-plug has been neatly tucked into the little pocket tray there, and has been hard-wired directly to the trucks ignition/power sources! When I fire the truck, powers up; turn it off, powers down! CLEAN -- CLEAN -- CLEAN! I love it:
Also, MCOR got rid of my "plug-in" Power Inverter and installed this one to the floor up under the dash in the center hump of the truck so that I can plug my laptop in to this instead! Again, this has been hard-wired, and all the wires neatly tucked away and out of sight! Score:
They went ahead and also hard-wired my Radar Detector, which eliminates another plug needed to be down there in the way, and also allows the detector to come on/off with the truck's power as well:
And as mentioned before, here is my custom Bass Knob install
lol...
And now in its new home
Prior to visiting with the guys at MCOR, I had just had the box shoved behind the seats and a few pieces of wood acting as a brace to keep it from moving (ghettttto)...
Now, it's all fastened into place w/bracketry (no more wood blocks, lol)...
One of the main reasons why the power kept cutting in and out, or so we thought, was the Cap - and it not being wired correctly, or not working properly... Turned out the Cap was fine - it was my power source (lead) wires. So I had MCOR upgrade all the wiring and fuse links, and what a difference! Not a single issue!!!!
This is the wiring on the Cap before MCOR:
After:
The power lead was actually what wound up causing the issues with the cutting in and out. The fuse holder cracked and the fuse kept arcing the power somehow and actually burnt up inside the fuse box and was almost welded to itself... Weird shit! Wiring under hood before MCOR:
Cleaned up, all new fuse, wires, etc - installed at the power box instead of at the battery:
So for $100 here is what I got:
All new power wires
All new fused link
All new RCA's
All new stereo wires
All wires loomed and neatly tucked away
Box fastened with bracketry
Bass Knob installed correctly
Radar Detector hard-wired
Power Inverter mounted and hard-wired
Tri-Port Power Strip mounted and hard-wired
Cap diagnosed, re-wired, and re-installed correctly
And a clean, neat, setup that works like a charm, and does everything I asked of it and the guys at MCOR!!
So, I got a TON of shit done, and a ton of cleanup on misc bologna that I hated, and the results were definitely worth the price! My truck doesn't cut off, the stereo doesn't cut out, the electronics are all neatly tucked away and fire on when the truck is turned off, and shut down when the truck is off... This shit was well worth the $100 I paid the guys at MCOR to get the truck right!!
Not only that, but I was driving down the road and my truck completely shut off one day, and I had no power. I was like WTF? So I had just recently met the guys over at MCOR Automotive on US41 just north of SR54... So I made the call & Matt got me in that Saturday to get things diagnosed, fixed, and cleaned up!!
lol...
After:
All new power wires
All new fused link
All new RCA's
Yeah, maybe so, but either way - not a big deal to me. For $100, I have ZERO complaints
If/when I upgrade the stuff, and spend a little more money on doing mids/highs/etc, maybe at that time I'll make sure I have them upgrade to shrinkwrapped wiring, etc. But at the cost I paid, I'm luck to have even got electrical tape
I know with your experience you have seen this stuff before and if you look really closely at his photos, you will see the texture to the tape. This TR member has been around for a while and I am sure if we ask him a year from now, he will verify the Ford wire loom tape is still completely intact (also keep in mind, we had no idea Josh was going to take photos for the web-this is our everyday practice-most customers never even notice). This is the same stuff we use for "high security" alarm installs and you can't buy it off the shelf. When we put in a "high security" alarm, and with the help of this factory tape, you will NOT even be able to detect ANY alarm wiring has been added-completely stealth. I even have two other shops that actually buy these rolls from us by the case (pretty high profile shops I might add).
We usually would shrink wrap but there was quite a bit of work for the $100, the time line, and the customer was looking for everyday practicality on a budget. So this was a "get it fixed safely with no frills but clean" repair. He is not looking to win any shows and for what he's got, the system sounds great. If it were show budget, we would have just built a fake wall and you wouldn't even have seen the wires at all.
My installers are instructed to wrap every wire loom with the Ford Loom Tape just as the factory did so that there won't be any future failures EVER. I am sure you would agree, most shops do not put forth this extra step (especially at this price).
Matt-check out these deals: https://www.tamparacing.com/forums/m...ood-stuff.html
MCOR Automotive LLC
mcorautomotivellc@verizon.net
www.mcorautomotive.com
1635 Dale Mabry Hwy Ste 3
Lutz, FL 33548
(813) 362-5454
"TR Official 12V Shop"- Automotive Audio/Video/Security (JL Audio, Alpine, Hertz/Audiosn, ARC Audio), Window/Tail Lamp Tint, Custom Wheels, Clear Shield, automotive upholstery and leather conversions, "All the Above!"
MCOR Automotive LLC
Lutz, FL 33548
(813) 362-5454
On one hand, it looks cleaner minus the capacitor - there should be a distro block and one set of terminals to the cap.
On the other hand, you spent 100$ on simple stuff you could have done yourself.
one thing that should never be done in wiring the amps and cap power wire to that stock battery cable it should have been installed right to the battery now on top of all the trucks stuff running off the lil stock 5 ga wire you got a amp and cap too.Thats how fires can start.But other then at A++ work and I have seen some good and some very bad shit work for best buy.
2008 Acura TL DD
1998 Beater Ranger DD
1994 Ford Mustang Project
2008 Acura TL DD
work looks clean, i know the tape you are talking about - never see a shop use it corrctly - 2 ++ if you do, and for $100 - you wont be in business long. TOO CHEAP, next you will be building boxes for free like many others on here.
You guys are great!! Matt will have my business 10-fold from here on out. I think he was well aware of the intentions that I have w/several other projects that I have lined up to be completed & that may be why he went out of his way, and over & above what "the norm" would consist of...
It's called paying it forward, and great customer service... Word of mouth advertisement = referrals = money = increased revenue, etc... Matt's a great business-man and knows what he did and how it was priced!
Thanks again Matt, I'll see you this week for the Vinyl & maybe we'll talk about those speakers you are considering carrying.
-Jo$h
His next stage will involve the ground upgrade, the power terminal upgrade, 2 guage wiring back to a dist. block, and addition of all new mids/highs and another amp. Later time, Later budget.
There is no safety concern with this cable setup and it is extremely common for a setup this small. Total amperage drawn in under 60 even with system turned all the way up!
MCOR Automotive LLC
Lutz, FL 33548
(813) 362-5454
MCOR Automotive LLC
Lutz, FL 33548
(813) 362-5454
