Can someone decipher this?
Old Oct 14, 2008 | 08:38 PM
Bowtie's Avatar
is sorta fast
Default Can someone decipher this?
this might be a question for notladstyle or someone like that... its some kind of circuit
Project Snowsled
Powered by LT1
Monroe/ Belltech Suspension
2.5" True Duals with Flowmaster 40's
Built 700R4 By: Tim Moye Transmission
CSR Electric Waterpump
Old Oct 14, 2008 | 08:43 PM
the727kid's Avatar
Looks almost like a crossover design, with some crap in there that I don't know what it is lol.
Need anything installed or built? PM me.
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Tweets: Image Dyamics CD1pro mini horns
Mids: Sundown Neo Pro 8s
Amp: Kicker IX500.4 (2)
Sub Stage
Subs: (2) Dayton Audio 15" HF
Amp: Kicker IX1000.1
Old Oct 14, 2008 | 09:08 PM
Bowtie's Avatar
is sorta fast
well its to directions in building a laser power supply.. its used to control power so your not sending direct power to the diode so it wont burn it up.
Project Snowsled
Powered by LT1
Old Oct 14, 2008 | 09:32 PM
Kyleisme's Avatar
well what did you want to know? you have a power source and circuitry.. where is the question? what exactly did you need to know?
Old Oct 15, 2008 | 11:24 AM
Bowtie's Avatar
is sorta fast
well if you read the title you will see the question.. the question is in big BOLD letters and appears at the top browser
and incase you do not have a vocabulary
decipher= convert code into ordinary language..
i just need all of those labeled into ordinary english and not just 3 letter abbreviations
Project Snowsled
Powered by LT1
Old Oct 15, 2008 | 01:31 PM
Notladstyle's Avatar
King of Ricers
That is as simple of a circuit as you can get.
You need the Lm317 - it has three prongs on it. the middle prong sets the voltage, the left is input and the right is output.
The thing with the 100ohm over it is a variable potentiometer, it varies resistance from ~0 to 100 ohms.
you need a 47uf capacitor rated for at least 25 vols and a 1ohm resistor.
The circuit is apparently designed so that you can measure the power output to the diode by way of a DVM across the 1ohm resistor. The wattage will be the square of whatever the dvm display reads.
notladstyle.blogspot.com
Old Oct 15, 2008 | 02:01 PM
88RedRex's Avatar
Protected Taurus .45/.410
it looks like it runs the flux capacitor on the car, lol
New sig. coming soon
Code 52 VTAK On A Switch
MCOR Automotive LLC
http://www.mcorautomotive.com/
PM MCOR for any electronics, upholstrey, accessories or window tint (813) 362-5454
They will take care of you as they did me
