amp help
Old Oct 8, 2008 | 05:26 PM
SkwervE's Avatar
realer than most
Default amp help
well months ago my ground wire came off my amp and i was putting it back on and when i was screwing it down my friend decided to take my ebrake off and the car rolled and the screw driver touched the ground to the top of the amp and now the only way the amp will come on is if the screw driver is touching both the ground and the top side of the amp where it touched when the car rolled..
any way i can fix this?
Old Oct 8, 2008 | 05:46 PM
the727kid's Avatar
Sounds like the internal ground may be blown. I bet if you open it up you will see it burnt right by the ground.
Need anything installed or built? PM me.
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Tweets: Image Dyamics CD1pro mini horns
Mids: Sundown Neo Pro 8s
Amp: Kicker IX500.4 (2)
Sub Stage
Subs: (2) Dayton Audio 15" HF
Amp: Kicker IX1000.1
Old Oct 8, 2008 | 05:51 PM
SkwervE's Avatar
realer than most
i opened it and it wasnt burnt.. nothing was noticeably wrong..
Old Oct 8, 2008 | 06:40 PM
the727kid's Avatar
Have you tried using a new wire for the ground?
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Sub Stage
Old Oct 8, 2008 | 07:57 PM
SkwervE's Avatar
realer than most
no.. both sides of the wire are perfectly clean and the ground is mounted pretty good..
Old Oct 9, 2008 | 08:10 AM
luke81's Avatar
Some amps use the chassis of the amp to distribute ground to different parts of the board. It sounds like the trace(or even the small wire in some cases) that links the ground terminal to the chassis is blown. Thats a very uncommon problem, but it would be possible. Was the amp turned on, or power already in the positive wire while you were hooking it up?
Luke
Audio Expert
11203 49th St. North Unit A3
727-573-2626
www.audioexpertonline.com
Audio Expert's Facebook site
Old Oct 9, 2008 | 08:31 AM
the727kid's Avatar
Luke - When is the new shop opening? I need to get a quote on something (I always forget something when I go up there lol)
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Sub Stage
