Questions...
Old Sep 25, 2008 | 11:35 AM
94civiclx's Avatar
Default Questions...
Alright heres my deal. A cell went out in my freakin battery took my cd player highs amp and 1 channel of my lows amp with it...talk about a shitty day. I got a new deck new highs amp. But now im looking for lows and dont wanna spend a ton of money on what i need..that sucks because my sucks are 1400watts peak 750rms. So i found a diesel audio amp 1100watts rms for 100bucks...does anyone know about them? is it worth trying? thanks.
(also should i put a fuse on my ground? notice my lows and highs amp ground connect was blown out after the cell went bad)
Old Sep 25, 2008 | 12:46 PM
jermwarfare's Avatar
Talking
Sure and i just so happen to have ground fuses in stock 19.99
Old Sep 25, 2008 | 12:48 PM
btw i was just kidding completely useless
Old Sep 25, 2008 | 12:59 PM
MCOR's Avatar
Ground fuse? There would be absoulutely no reason to do that-I have NEVER seen one installed at any level. Your scenario actually sounds like the car was jumped and cables were connected in reverse. I have also seen that type thing happen when a car is hit by lightning (lightning does funny things to mediocre grounds).
Diesel products? Maybe one step above flea-market specials (ie: Boss, Pyramid, etc)--MAYBE. Even one of my main electronics distributors steers all his accounts away from their products. He told me a while back that the DOA ratio is almost 30% (meaning 3 out of 10 Diesel products are returned defective out of the box)!
You may be better off purchasing a used amp from a reputable TR member or reputable pawn shop if that is all you can afford. Used amps are usually trouble though (there was a reason that it is no longer in someones car...)
Matt-check out these deals: https://www.tamparacing.com/forums/m...ood-stuff.html
MCOR Automotive LLC
mcorautomotivellc@verizon.net
www.mcorautomotive.com
1635 Dale Mabry Hwy Ste 3
Lutz, FL 33548
(813) 362-5454
"TR Official 12V Shop"- Automotive Audio/Video/Security (JL Audio, Alpine, Hertz/Audiosn, ARC Audio), Window/Tail Lamp Tint, Custom Wheels, Clear Shield, automotive upholstery and leather conversions, "All the Above!"
Old Sep 25, 2008 | 01:13 PM
94civiclx's Avatar
i figured a ground fuse would be useless just thought id through it out there.....thanks for the input i think i will start looking for another amp on here..the digital audio was a once in a lyfe time find 60 bucks for 4000watts peak 2000watts rms 1 ohm stable im sad now
Old Sep 26, 2008 | 05:15 AM
pnrcaraudio's Avatar
Default Diesel Amp
Hey I have never personally used Diesel Amps but there is a pretty long standing Shop over here in Pinellas that has been using Diesel for quite a few years as there entry level amps (Radioactive / Custom Edge Audio) and the owner never once had anything bad to say about the line that I heard.
Now as far as used amps unless you are buying it from either a reputable shop that took it out of the persons car themselves and tested it while still in the car or a reputable person then I would not recomend it because like MCOR said there is probably a reason why it is no longer in the persons car.
Old Sep 26, 2008 | 12:10 PM
NT_Hardcore's Avatar
bassheadsent.net
i know of a few people running some diesel amps and subs. havent had any probs yet and it gets the job done pretty well for the price...
http://www.bassheadsent.net/
