Chevy Guys w/Stereo....
What's the general consensus on installing a head unit in a newer Chevy model? The shops I've called have all been trying to sell me some $80-$100 unit for my truck. Some module to keep the door chime working, etc...
Is this for real? My truck is a WORK TRUCK model, no Onstar, no Power Windows, Locks or Mirrors, no Bose... NADA!
I bought a Double Din Kenwood DPX502, and wanna install it this weekend, but don't wanna blow an extra freaking hundred bucks to do eeeet...
Hook a ninja up, tell me this shit is ghey, and not necessary and I can get by with just the normal $25 worth of install kit/adapter/plug gimmick actions.............
You can do it with a cheap harness. I did it on my buddies truck. You will need to find your own ACC. wire though, I think I did a lil more too but not much.
Need anything installed or built? PM me.
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Tweets: Image Dyamics CD1pro mini horns
Mids: Sundown Neo Pro 8s
Amp: Kicker IX500.4 (2)
Sub Stage
Subs: (2) Dayton Audio 15" HF
Amp: Kicker IX1000.1
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Sub Stage
Hrmmmm...
So what "ACC" wire would I need to find? And what for?
I'm a total electronics
- so help a brother out. I'm having another forum member help me with the install of the head unit, amp, cap, and subs. I bought the gear from him, except for the head unit, and want to be able to install it all...
I'm just not sure I can justify blowing another $100 on it, when I'm not even supposed to be spending money on my truck
The wife made me promise to wait until I bought her a house
- so help a brother out. I'm having another forum member help me with the install of the head unit, amp, cap, and subs. I bought the gear from him, except for the head unit, and want to be able to install it all...I'm just not sure I can justify blowing another $100 on it, when I'm not even supposed to be spending money on my truck
You are supposed to use the GMOS module which is about $100. However, if you don't care about chimes, etc. Most shops don't know about this alternative because the book doesn't list it as an option but you can use another alternative wire harness. It includes and extra long wire that you have to shoot down to the steering column or the fuse box to catch your own accessory feed however. I have the harnesses in stock (we do alot of work for fleets like verizon and brighthouse that have work trucks and need cheap radios) and the install kit 99-2003 that you would need for the 2006 Silverado. Give me a call as you are not going to find this harness in Best Buy or any other local shop. Just know that your chimes and seatbelt minder dinger will be GONE!
Matt-check out these deals: https://www.tamparacing.com/forums/m...ood-stuff.html
MCOR Automotive LLC
mcorautomotivellc@verizon.net
www.mcorautomotive.com
1635 Dale Mabry Hwy Ste 3
Lutz, FL 33548
(813) 362-5454
"TR Official 12V Shop"- Automotive Audio/Video/Security (JL Audio, Alpine, Hertz/Audiosn, ARC Audio), Window/Tail Lamp Tint, Custom Wheels, Clear Shield, automotive upholstery and leather conversions, "All the Above!"
MCOR Automotive LLC
Lutz, FL 33548
(813) 362-5454
I got the harness at Wal-mart for $2 at it worked fine haha, just extended my own wire. The ACC wire is the red wire coming from the HU. Look up alarm wiring diagram for your truck and it will tell you what wire under the dash is the ACC wire, tap into that.
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Sub Stage
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Sub Stage
"Scosche Car Stereo Wiring Connector 94-06 GM:
$6.78
This '94-06 GM car stereo connector adapts the wiring of your new car stereo to the existing factory wiring harness.
$6.78
Availability:
Online
Not Sold In Stores
"Not sure which WalMart you found it at or how you got it for $2. They state it is special ordered and only sold online for $6.78.
MiDiablo, if you want it today, call me. If not, you could always do it the good old fashioned "backyard" way and cut off the old connectors for a manual splicing. I'll give you the printout while you are here so you know which accessory wire to hit at the steering colomn harness or the BCM below it...
MCOR Automotive LLC
Lutz, FL 33548
(813) 362-5454
MCOR Automotive LLC
Lutz, FL 33548
(813) 362-5454
Check your PM's
MCOR Automotive LLC
Lutz, FL 33548
(813) 362-5454
MCOR Automotive LLC
Lutz, FL 33548
(813) 362-5454
Directly from Wal-Mart's webpage:
$6.78
$6.78
Availability:
Online
Not Sold In Stores
$6.78
$6.78
Availability:
Online
Not Sold In Stores
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Sub Stage
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Sub Stage
Anyone that can confirm or deny that the only negative effect of not using the module is the loss of seatbelt dinger and door chime? What about "fuel low" and "door open" or "lights still on when you got out of the truck idiot" and whatever other "beeps" the truck makes??
