04 G35 coupe stereo problem...help??
Old Jul 4, 2008 | 12:21 PM
GiRlS_rAcE_2's Avatar
RuN uR cAr NoT uR mOuTh
Default 04 G35 coupe stereo problem...help??
radio plays fine and sounds good but when i play any cd the speakers take turns cutting on and off or just both cut off at the same time which is most of the time... if i hit bumps in the road or brake it will come back for a little while then go off again or they are very dim at the highest volume .... speakers arent blown and i checked for anything loose or any wires disconnected in the amp .... i disconnected and reconnected everything and still nothing... any1 have a clue what could be the problem?
Old Jul 7, 2008 | 08:54 AM
TBSpyder's Avatar
Sounds like it's the amp, an internal short. You'll probably need a new amp. Exactly what all do you have that's not factory??
Old Jul 7, 2008 | 09:38 AM
the727kid's Avatar
Sounds like the HU if it's just when you play CDs.
Need anything installed or built? PM me.
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Tweets: Image Dyamics CD1pro mini horns
Mids: Sundown Neo Pro 8s
Amp: Kicker IX500.4 (2)
Sub Stage
Subs: (2) Dayton Audio 15" HF
Amp: Kicker IX1000.1
