whining noise
so my friend just got this jl 4 channel amp to power his inf. kappa interiors and when he hooked it up, he gets a whining noise coming through all of the interiors and when he hits the gas, the noise gets louder! i talked to a few ppl but keep getting diff answers as to what it can be. someone said to get something (forgot what he called it) to plug your rca's into. he said its a small cube or something. another person told me its a bad ground! his amp with his sub is fine. no whining coming out of the sub. he also has a capacitor hooked up....dont know who did the install! would it be two seperate grounds for the sub and interiors? doesn't the ground and power come off of the capacitor? im really lost and could use some insight please! reps given and thanx in advance!
I am going to guess it is the headunit. Take a piece of raw wire and wrap it around the metal part of the RCAs (behind the HU) and then ground that wire to the frame of the car.
Need anything installed or built? PM me.
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Tweets: Image Dyamics CD1pro mini horns
Mids: Sundown Neo Pro 8s
Amp: Kicker IX500.4 (2)
Sub Stage
Subs: (2) Dayton Audio 15" HF
Amp: Kicker IX1000.1
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Sub Stage
Its alternator whine man, and all of that stuff could be a possibility. Make sure the paint where you have it grounded is sanded down to bare metal. If possible take a multimeter and measure resistance between the location you're grounding and the negative battery terminal. make sure everything in your system is grounded at the same location...not 3 feet away from each other.
The box your friend was talking about is a ground loop isolater, they work like 50% of the time so you could try that but it will cost you a little money...usually like 10-15 bucks.
listen real close to the sub and flip it to all pass for a couple seconds, sometimes the LP crossover will filter out the whine so you wont hear it as predominately as the highs amp. You can also check if you have bad RCAs by just getting a set off of a friend and tossing them from behind the deck back to the amp, not having to run them under the carpet, because as said...theres so much stuff it could be...I've even seen bad spark plug wires cause the issue in a couple instances
98 Eddie Bauer Explorer with single 12W7: 7th loudest vehicle in PA: Sold
93 Gutted Greddy Turbo and Zex Nitrous EG Hatch: Sold
07 Caliber with 13W7 and 20's: Traded
08 Ridgeline with all JL system: Traded
94 343whp D16z6 Del Sol: Sold
04 VW R32: Doin' Thangz
No prob man...good luck! its deffinatly not the funnest thing to have happen...I remember we had some simple stuff solve it too (an amp was mounted in the side wall of a navigator, the power wire was going on the bottom side of the amp...we rerouted it over the top of the amp and it solved the issue)
The common ground for the radio is the ground wire that runs to ground from the harness.
If anything you should route the harness ground to the chassis at a sanded spot with a stainless steel screw.
Proper wiring in the first place > that ugly picture ^
Actually, I would agree with the wrapping of the RCA's to a ground. When you are doing a high volume of FM modulators (dealership headrest TV's, etc.), amp installs, etc, this is a great known "down n dirty" method to isolate the issues and quickly. I have seen many vehicles that had all brand new gear installed, good equipment with power and RCA's run opposite sides of the vehicle, still getting the whine. Even gone as far as running a temp. jumper for amp ground to the same factory radio wire ground on the vehicle still to get a whine. Sometimes it just cannot be contained even when completely and professionally wired. We try to only use ground loop isolators as a last resort because as aforementioned, they are only about 50% successful.
That being mentioned, ALWAYS start with the basics- good equipment, good wiring, sanded and tight amp grounds, RCA's run completely opposite side of vehicle from power cabling and kept completely seperated, etc. If all else fails, ground the RCA's (I would wrap the raw wire as in the pics but we have found that it is more successful sending the other end of the wire NOT to the radio chassis but to the factory ground wire going into the factory radio harness).
Do it for a living managing multiple installs per day (all done professionally and properly), and you are bound to run into this a few times! Ask any professional installer. The difference is the installers who can actually fix it. We probably get at least one of these jobs a week where someone has ripped their hair out going over wiring, installing isolators, etc just to find that this method ends up being the only one that works!
Matt-check out these deals: https://www.tamparacing.com/forums/m...ood-stuff.html
MCOR Automotive LLC
mcorautomotivellc@verizon.net
www.mcorautomotive.com
1635 Dale Mabry Hwy Ste 3
Lutz, FL 33548
(813) 362-5454
"TR Official 12V Shop"- Automotive Audio/Video/Security (JL Audio, Alpine, Hertz/Audiosn, ARC Audio), Window/Tail Lamp Tint, Custom Wheels, Clear Shield, automotive upholstery and leather conversions, "All the Above!"
MCOR Automotive LLC
Lutz, FL 33548
(813) 362-5454
I don't know who started that ridiculous rumor that wrapping copper wire around the grounds will help anything.
