How to hook up 2 amps?
Old Mar 2, 2008 | 09:17 AM
brownguy06's Avatar
Big Nate
so thats makes a big difference when there is alot of play between the rca cables or when there crossed?
Old Mar 2, 2008 | 10:26 AM
Notladstyle's Avatar
King of Ricers
Long low quality RCAs can cause two problems:
The RCA cables have a shield over the signal lead that is grounded at the source - when you link two amps together via RCAs you are also linking their grounds. So if the impedance(resistance) to the amplifier's true ground (the wires you run to the chasis from the - post) is significantly different, the alternator will produce noise between the two amps.
The longer the RCA wires, the more aluminum shield there is protecting the signal lead. The aluminum is meant to reject emi from other electronic components and RF in the air from your signal (to keep it from getting amplified) but if you have excessively long RCAs, the aluminum shield will actually act as an antenna and gather up all the EMI and in turn the signal lead will send that EMI to the amplifier.
Cliffnotes:
Long RCAs make alternator hum and introduce static into your signal.
notladstyle.blogspot.com
Old Mar 2, 2008 | 11:55 AM
brownguy06's Avatar
Big Nate
ook so thats why somtimes you have that hum or whistle noise come out from you speakers when you driving then.
Old Mar 2, 2008 | 01:14 PM
King of Ricers
roger.
Old Mar 2, 2008 | 01:22 PM
brownguy06's Avatar
Big Nate
ok got it...
