Triangle or X?
I snatched the bitmap you posted, and worked with that. I had to manually adjust some of the spacing, but I think its pretty good.
While not the greatest pic, this is what the toolpath looks like...I had to just take a picture of the screen, since it doesn't output into anything postable.
The outside is the 1/4" cutter making the 102.3mm cutout, and each hole is 5.2mm. And yes, the holes will be perfectly round...the pic makes them look a little funny.
Close?
Toby
Close?
Toby
Close?
Toby
Close?
Toby
Instead of taking a photo of the screen, leave the screen up on what you want and press the "Print Screen" button on your keyboard and paste (ctrl+V) onto MSPaint. Save as a JPG and post up here
Reason I never pursued it are it would require a lot more money and time to construct (after the chips had been programmed), and it is illegal to have more than a two state flashing light on the front of a vehicle.
He says it's waaay too much work. I don't think it'd be that bad, and the payoff would be sweet.
you build it and ill gladly conceed its an easy project.
I just got a look at a the template for a circle with a 24led array and it looks GREAT. I cant wait to start construction on it. Toby's Router is full of much win.
If this one looks as good as I think it will, I might make a 3 row 72 led foglight that would be suitable as a driving light next!
Heres the template:
Heres the template:
Now there's some logic!
