slight problem with sub
My guess is that you are over driving the amp, causing it to distort. When this happens, you start sending a square wave to the sub, which can make it sound like it is hitting something (kind of a 'barrank' sound). Turn down your gain, and see if it is still happening.
Toby
Toby
if anyone wants to guess at it list the things and I will go one by one
If you wire the high outs form a deck to RCAs, it will work at very low volumes and fuck up at high volumes.
I can only see it working at very low volumes.
high level output is an amped signal from the headunit that varies from 0-20v. the low lvel input on your amp is designed for 0-4v maybe 8v but no more than that.
I doubt thats the problem unless you have a high to low level converter box that has the gains turned all the way up on it.
I think you have your 1.5ohm coils wired in parallel whicn is too low for a 1000/1
yeah... From what I read, the 1000/1 is a 1.5ohm stable amp so that would probably be the reason you are getting the pop. I think its designed to run dual 13w7s.
Now there's some logic!
