Big 3 question..
Old Nov 7, 2007 | 03:26 AM
93ex's Avatar
Just Ledoux it!
Default Big 3 question..
I'm going to run 0/1 to a distro then 4 ga to my amps, really the 0/1 is overkill, since I'l running ~800 watts. Can I just upgrade my big 3 with 4ga, since I have a shit ton of it lying around, or do I have to buy more 0/1?
Old Nov 7, 2007 | 05:19 AM
P057's Avatar
isuck
I'd use at least 2ga. But I reccomend 0/1 ga just for the fact that it'll be easier to upgrade upon in the future if the need ever rose up.
Originally Posted by TNathe
so because wikileaks doesnt have it means it didnt happen? Now there's some logic!
Old Nov 7, 2007 | 07:01 AM
Notladstyle's Avatar
King of Ricers
Id run 4ga all the way through. The extra cash in wire isn't really worth it.
notladstyle.blogspot.com
Old Nov 7, 2007 | 07:16 AM
P057's Avatar
isuck
Where is that site you used to post up all the time that had the "wire to power" diagram?
Old Nov 7, 2007 | 10:27 AM
the727kid's Avatar
You should be fine with 4 gauge to the back. But that 0 gauge will help voltage at the amps. I would only do the big 3 in 0 gauge. Most factory wiring is already 4 gauge.
Need anything installed or built? PM me.
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Tweets: Image Dyamics CD1pro mini horns
Mids: Sundown Neo Pro 8s
Amp: Kicker IX500.4 (2)
Sub Stage
Subs: (2) Dayton Audio 15" HF
Amp: Kicker IX1000.1
Old Nov 7, 2007 | 10:58 AM
93ex's Avatar
Just Ledoux it!
Well, I already have the 0, so I'd rather not buy another run of 4 to run to the amps. Sure, it's overkill, but it's already here. I was really just thinking about my big 3 upgrade, and if it's really going to be that much of a difference between 0/1 and 4 gauge, or even dual 4 gauge runs.
the727kid's Avatar
If you have extra 0/1 use that, if not do dual 4 gauge runs.
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Sub Stage
Old Nov 7, 2007 | 11:28 AM
93ex's Avatar
Just Ledoux it!
I dont think I'll have extra 0 beyond a few inches. I figured dual 4 gauge in some loom would be just as good.
Old Nov 7, 2007 | 12:04 PM
King of Ricers
Ill take the make/model of a car that runs 4ga alt -> bat wire. thats gonna be my next vehicle.
0ga compared to 4ga over the 2-3ft you will need for the big three will make absolutely no difference since your alternator cannot produce enough power to bring a 4ga wire to capacity... The ground wire should be as big as you can make it though.
Old Nov 7, 2007 | 12:35 PM
the727kid's Avatar
Every car in my household, 01 Civic, 97 Caddy, 06 Accord, my boys Charger uses a small 0 gauge/thick 4.
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Sub Stage
