is this a bad idea
Old Nov 1, 2007 | 09:19 AM
bryson240's Avatar
Default is this a bad idea
have an mdf box. then just put a layer of fiberglass and resin over it so i can paint it?
Old Nov 1, 2007 | 09:29 AM
MilanoCivic97's Avatar
smooth as its name.
not a bad idea at all. you could probably get away with painting just the mdf with a high build primer and a few coats of paint though.
Old Nov 1, 2007 | 09:39 AM
the727kid's Avatar
Make sure you round over all the corners though!
Need anything installed or built? PM me.
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Tweets: Image Dyamics CD1pro mini horns
Mids: Sundown Neo Pro 8s
Amp: Kicker IX500.4 (2)
Sub Stage
Subs: (2) Dayton Audio 15" HF
Amp: Kicker IX1000.1
Old Nov 1, 2007 | 10:56 AM
bryson240's Avatar
alright becuase i want to have the fiberglass look but my friend but a full fiberglass bos and it sounded like crap like rattley
Old Nov 1, 2007 | 12:29 PM
P057's Avatar
isuck
what?
Originally Posted by TNathe
so because wikileaks doesnt have it means it didnt happen? Now there's some logic!
Old Nov 1, 2007 | 12:49 PM
bryson240's Avatar
he made a fiberglass box and it was like rattley sounding then he made a mdf box and it was clean
Old Nov 1, 2007 | 01:41 PM
P057's Avatar
isuck
A fiberglass box shouldn't sound "rattley" at all. The fiberglass makes the box a one, super-solid, airtight piece.
pour the fiberglass and "paint" it all on the inside of the box, this will make it even more solid and airtight. Then you can paint the outside of it just fine.
Old Nov 1, 2007 | 02:14 PM
integralsgreen's Avatar
i use spray polly. mdf seems to suck up primer like a sponge. and with a good urethane primer it can get expensive. coating it with fiberglass resin works excellent too just a little harder to sand smooth. you can also mix some bondo in with some fiberglass resin, mix it up to a good sprayable viscosity, add mek hardener and spray it out of a paint gun. it will lay flat so less sanding, and easier to sand than just straight resin, kind of a poor mans spay polly
