amp trouble, need help`
i have an audiobahn 8002t amp
and i have 2 12'' kick cvr's running off it
amp cuts out i think its due to overload,
would a Boss GT2500D Riot GT Class D Monoblock run it better
rated at 900 w rms x 4 ohms, and i think thats better then the audiobahn amp i'm running, let me know, thanks,,
i dunno hwo to wire it parallel to the amp, so i think thats why it is messing up
Why don't you ask the guy who's selling it you goofball.
Wait, that's me.
What are the kickers rated at @ what ohms? I'll tell you if it works fine or not.
Btw it's not rated at 900w at 4ohms.
Hey, that Boss amp is much more powerful and is stable at a much lower ohm load than your Audiobahn amp was, Audiobahn is pretty good stuff (and it is not owned by Pyramid, Audiobahn actually own about seven other brands to include Alphasonic , Ichiban and Swiss Audio To name a Few) but the T series amps were not designed to go below 4 ohms mono and it sounds like that might be what you did, that boss amp is a Class D amp and is stable at 2 Ohm where it will do 1500 RMS Watts, so another words it is far more powerful than your Audiobahn Amp. You need to find out what ohm load your subs are because Kicker CVR's can come as Dual 2 ohm or Dual 4 ohm If they are dual 2 ohm CVR then you do not want to use the boss amp if they are dual 4 ohm CVR's then there is a way to wire them up to that amp and have them kick out some awesome bass
Now there's some logic!
