simple question, let me know what it could be
I have a civic, like nealry ever person on earth, and have 2 kicker 12s with a kicker amp, amp stays on and plays then I turn it up loud and it plays for like maybe a second and then just stops, kinda like its over heating the amp, or something but it plays at lower levels ok but usually i turn it up, everything is new wiring and new rca's just problem withg sound,
I have tried leaving radio on and unplugging like 1 rca at a time and if I pull one, it seems to get louder but when I turn it up it cuts out...
another quick question I wanted to be answered is if you have your amp bridged...do you need to put a Y adapter on your rca to make it the like the white rca would y into both L and R on amp? or would you just leave it
feed your amp with right and left rca normally - bridge is on the output of the the amp.
you are clipping your amp when you turn it up!!!
need to check wiring of amp - to low ohm load!
+1 (fixed sentence..)
1. what are the impedences of your speakers? (4ohm, 8ohm, dvc?)
2. what impedence is your amp stable to?
buying parts i don't need with money i don't have to impress people i don't know.
-The local car audio/home theater guy. pm me for all your audiophile needs.
heres what you do. go to radioshack or autozone or wherever and buy a multi-meter that can read ohms, take the speaker wire out of your amp and test it for ohm load. if it says anything lower than 2 you need to re-wire your subs. if it says something else and its the rare option that you have a kicker two channel amp (they only make one) you may have a bad channel on your amp
you don't need to see my identification.
when i had this happen to me, i did 3 things 1.got another battery2. got a bigger ground wire 3. got a different ground source and it has yet to happen to me again, it sounds like you have the same problem but i could be wrong, i did all the same things you did, i even bought new RCA's and i ran a new remote wire i hope you solve your problem, good luck
New sig. coming soon
Code 52 VTAK On A Switch
MCOR Automotive LLC
http://www.mcorautomotive.com/
PM MCOR for any electronics, upholstrey, accessories or window tint (813) 362-5454
They will take care of you as they did me
MCOR Automotive LLC
Now there's some logic!
