simple question, maybe easy fix?
Old Jul 26, 2007 | 06:23 PM
  #21 (permalink)
93ex's Avatar
Just Ledoux it!
Originally Posted by back2Nissan
vehicle. According to your question, the amp is not shutting off just the radio.
Just a "well no shit" but if your head unit shuts off the amps are shutting off too.
Old Jul 26, 2007 | 09:05 PM
  #22 (permalink)
steveokinevo's Avatar
drives 1 loud yota
+1, like i stated at the begining, i am having the same problem and have noticed not only the head unit shuts off, the amp also.....i also have a 5 farad cap (not .5) and still have these problems.most stereo shops i have talked to say bigger alternator will help\fix the problem
Gamertag: st3veokin3vo ADD ME!!!
Originally Posted by That-away!
Lol sorry didn't really look as good as i thought it did...but theres no need for the smart ass reply bud.
... nvm,I kinda start to expect that stuff from PnR cutomer service...
Old Jul 26, 2007 | 10:12 PM
  #23 (permalink)
back2Nissan's Avatar
Bakermotorsource
Oh Lord here we go...sorry for the mis-understanding. If the radio stays on and the amps go out then you would check the grounds, power, impedence etc. at the amp, as someone stated earlier. If the head unit goes out...its a different story it's a different circuit. The Jeep Cherokees used to have voltage problems at the radio and drop down to 9 volts in the factory wiring harness. We would have to run a seperate wire to the battery and use a relay wired to ignition to get a true switched 14.4 volts at the radio with the car running. Anyway, good luck on your trouble shooting.
Steve Baker
Owner / Builder
P.S.
"If you don't know what you are doing, at least do it neatly"
Old Jul 27, 2007 | 04:04 AM
  #24 (permalink)
P057's Avatar
isuck
I never said YOU had a .5... anything short of double digit farad caps are pretty useless, and will NOT FIX THESE ISSUES especially if you do not listen to quick 'poppy' bass, where the electrical system has time to recover.
It is muuuuch better if you get a 2nd battery and it will only truly FIX it if you get a better alternator.
But what the hell do I know? I've only done research on this and tested a lot of it... I've had tons of these problems for months with my car and successfully fixed it, shit I remember when I even used a cap...
It was the nicest looking, most well lit up and expensive voltmeter I ever bought.
Originally Posted by TNathe
so because wikileaks doesnt have it means it didnt happen? Now there's some logic!
Old Jul 27, 2007 | 04:41 AM
  #25 (permalink)
Notladstyle's Avatar
King of Ricers
There goes that "pretty much useless" again.
second battery is not necessary unless there is a severe power draw in the thousands of watts rms.
For the type of music you listen to, a capacitor may help "clean up" the punchiness of the bass, as in make it more defined. The main issue of your headunit though will more than likely not be solved.
The headunit probably has a shut off protection at around 10 volts. a capacitor might be able to hold the voltage above that for a short period of time, but the underlying cause of WHY your voltage is dropping to below 10 volts is the real issue you need to address.
You may just need a replacement OEM alternator. It may come as a surprise, but just like every other piece of equipment in the world, the alternator's peak and RMS output fall as it ages and the components become polarized/worn.
notladstyle.blogspot.com
Old Jul 27, 2007 | 11:10 AM
  #26 (permalink)
P057's Avatar
isuck
Won't help my music. I listened to music that had looooooong, deep bass drops. No punchiness here.
I agree
Old Jul 28, 2007 | 06:54 AM
  #27 (permalink)
drives 1 loud yota
ok, just went to see about getting a new alternator.... so having them rebuild me 1 from 70amps to 100amps is gonna cost $200(take it out, rebuild more powerful, put back in and test and tweak it). then a couple weeks later a yellow top battery.think thats all good\will work???
