cd player help
Old Jul 22, 2007 | 06:09 PM
tapout's Avatar
Default cd player help
It wont turn on but the clock works for a few seconds and it will accept and eject a cd. I tried reseting it nothing happened. bought a new wiring harness for it and a new fuse. Any ideas?
Old Jul 22, 2007 | 06:57 PM
Notladstyle's Avatar
King of Ricers
you must supply power to the red accessory wire in order to tun it on.
As it is now, you are only supplying power to the yellow constant 12v wire which allows CDs to eject and the time display to turn on.
If you have the red wire connected, try connecting it to with the yellow wire on the 12v constant.
notladstyle.blogspot.com
Old Jul 22, 2007 | 07:17 PM
tapout's Avatar
bro I just tryed that and it worked for a few seconds and then something shorted out my dimmer lights and stuff shit what fuse/fuses did I blow
Old Jul 22, 2007 | 07:52 PM
GradeA_TireFryer's Avatar
All American, rice eater!
i bet you have the ground wired wrong - get a metal ground do not use the ground in the harness - tape off any wire not used to prevent shorts - replace fuses - you need to tell what kind of car it is in - can give more info
Old Jul 23, 2007 | 02:23 AM
tapout's Avatar
96 Jeep Cherokee
Old Jul 23, 2007 | 04:49 AM
use the braided cable as your ground watch for the dimmer/dash lights shop ground when off but 12+ when on
Old Jul 23, 2007 | 02:34 PM
tapout's Avatar
Thanks guys got it working again.
Old Jul 23, 2007 | 02:46 PM
P057's Avatar
isuck
so what was it that did it? Just a combination of everything or what?
Originally Posted by TNathe
so because wikileaks doesnt have it means it didnt happen? Now there's some logic!
Old Jul 29, 2007 | 06:20 PM
yaBoyE727's Avatar
how would you ground the wire to metal? just tape it or something?
Old Jul 29, 2007 | 08:57 PM
King of Ricers
you buy an O-ring connector and use a self tapping screw to drill it into a sanded part of the metal.
