any luck with rca adapters?
Yea I know there is like a 10 dollar one that goes underneath where storage thing is but then i would have two radios that is dumb and then the 150 dollar one is diff than my air controls I have an 07 honda so the controls are all diff those controls or only 03 04 05.
Ooo gotcha, I got some buddies at Metra I can see if I can find anything out.
Need anything installed or built? PM me.
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Tweets: Image Dyamics CD1pro mini horns
Mids: Sundown Neo Pro 8s
Amp: Kicker IX500.4 (2)
Sub Stage
Subs: (2) Dayton Audio 15" HF
Amp: Kicker IX1000.1
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Sub Stage
Btw, Where did you get that particular RCA adapter. Mine is a cheap-o one i guess. It is Audiopipe lol I got it from the flea market. I am not all that familar with them because i never had a stock dash kit with my system so i do not know good stuff from bad.
they convert the high voltage signal meant to go to a speaker to a low voltage preamp level for use with another amplifier.
would you need these if you were hooking up any speakers to any amp, or just amps that don't have with low & high pass Xovers?
I was going to run my speakers of a 4 channel amp but was going to just put a Y rca split and run it straight from the head unit without any RCA adapters.
cal car audio of largo fl and ask to talk to mike he can fix ur prob in secounds for free he can tell you how to bypaas the main harness without a conversion if it has factory securit like a civic its all in the deck
